Check engine light
I have a fabspeed exhaust, installed at 5K miles. Just had the 20K service done, the dealer installed the latest 997TT Porsche ECU map. A day after bringing the car home the CEL light came on. Anyone have something similar happen?
The dealer offered the option, he said it was the latest map from the factory. Claims was quicker, less lag, it was covered under warranty. What prompted the upgrade was my complaint that occasionally there was a slight hesitation on hard acceleration, above and beyone Lag. So far I like, excpet the CEL came on the second date.
So note to all modded cars owners: make sure you tell the dealer you do not need any ecu upgrades at the 20k service.
regarding the hesitation I am willing to bet it is your spark plugs, the TT seems to be hard on plugs and I had to change mine way before the 40k mile scheduled replacement, the hesitation which started around 21k miles went away with the new plugs.
It is safe to assume that the first thing the dealer will do is point to the Fabspeed exhaust as the source of the CEL? The tech said the ECU map was the latest available, I assume it is the same that is coming on the 2008s
ask for the codes. if they are due to a misfire then it is not the exhaust, it is either the plugs or the coils or both. ask what the codes are and you'll know what caused this.
BTW, is the 1st check up 15K or 20K? I thought I just got a mailer saying it's time for the 15K check.
I spoke to the dealer and he said the CEL could be the gas cap seal, or they may have knocked a sensor loose when they installed the belt-tensioners(?) that were making bearing noises. He said if the CEL was not flashing, not to be overly concerned.
I did the 20K service according to the warranty book.
Apparently there is a TSB at the dealers for 08 and some 07 cars to readjust the idle, that's why they rest your ecu. I was there today and asked about the topic while picking my car up.
Tony at PES told me that if the do reset it for some reason that he would simply reflash it for me on the house.
