GIAC
I am confused how to set the GIAC flashloader.
When I connect it to the OBD and press the read button, the read button keep flashing green and doesn't inform what is the current program (stock,pump or race)
If I press the pump button, the pump button flashing light green.
Then I disconnect the Flashloader, turn off ignition, turn on again and connect the flashloader.
I press the read button, the read button keep flashing green.
How should I use the flashloader?
According to the boost meter, on the sport mode my car boost is 1.2 bar till 4500rpm, then 1.1 bar till redline.
Is this GIAC Stock or Pump program?
I already installed the manifold, muffler and BMC replacement air filter.
