V1 here...simply n other choice in my experience. Maybe others are as good but I have yet t get a ticket with my V1 "on".
I use Valentine 1 in all my cars, even in my wifes car.
It seems V1 is the choice detector even though more expensive and only wind shield mount.
Originally Posted by whyb2nd
(Post 4585074)
I use Valentine 1 and swear it's saved me thousands over the years as well as my license and driving school.
The V-1 can't help much against laser guns, but it is much more sensitive than the SRX against other threats. |
Originally Posted by HUMMM 3
(Post 4621853)
I use the belt and suspenders approach. A V-1 combined with an Escort SRX both hard wired. The V-1 can't help much against laser guns, but it is much more sensitive than the SRX against other threats.
I have a passport 8500 and its saved my butt time and time again. Lately I am getting frustrated with all the false alarms here in San Francisco. Is it possible to re-program this detector to eliminate all X, and K signals? If not I will make the switch to the V1. Have never owned a V1 so can't compare. The 8500 is a great detector, especially for Ka signals (the one that counts). The Laser warning will literally give you a heart attack as it scares the daylights out of you. Especially since you know your as good as toast. The 3 laser warnings I have gotten so far didn't result in a ticket. The 997S next to me during my last laser encounter was not because he ended up passing me up during the warning. The HP is trained to go for the lead runner so he blew right by me and pulled over the other Porsche. Usually when the laser signal goes off you might as well start pulling over because your a dead duck. Your only hope is a laser jammer (not legal in California). The strategy basically is to jam the laser gun sending off an "error" message on the readout. He gives it a second shot and by then you have already slowed down to the speed limit and switched off your jammer right?
I have an 8500, saved me many times as well. You can def reprogram them, but I don't have the manual anymore. Can't be too hard.
My only issue is the mounting cups on the 8500- they suck. That alone may push me towards a V1 again. |
Check out the new escort 9500, looks sweet, less than the v1 as well.
My only issue is the mounting cups on the 8500- they suck |
Originally Posted by TT Gasman
(Post 4622613)
Originally Posted by WHB Porsche
(Post 4623965)
Aren't they supposed to? :)
(Post 4622613)
The windshield spot issue was in the old 964 cars, used different widow tx and glass composition back then, a non issue 993 onward.
The cups V1 provides seem to be the best I have used. treated right on application they stick forever.
Everybody done, lets close the thread, V1 wins again. I wish they would do a current shoot out with the comp.
