997 Turbo Forum 2005-2012
What is your oil consumption?
Old 07-13-2015, 10:03 PM
  #31
Boeing 717
Registered User
Boeing 717's Avatar
I don't think ive ever seen my oil gauge thingy go down one even one notch. So its probably pretty good.
Old 07-16-2015, 05:32 AM
  #32
jcnesq
Miserable Old Bastard
jcnesq's Avatar
I'm at 32K miles (6.5 years in) and my oil usage is very, very low. Added a half quart 6 months ago and I'm getting a notice oil is low so will add a little, though taking her in for an oil change shortly.
Old 01-04-2016, 12:52 PM
  #33
Quadcammer
Quadcammer's Avatar
Received 1,444 Likes on 836 Posts
57k miles
5k miles on oil change (blend 0w-40 and 5w-50 mobil 1)
approximately 1/4 of a quart added.
Old 01-04-2016, 02:18 PM
  #34
strato58
strato58's Avatar
Quad, why do you blend oils? Do you like the results?Ive been using the Mobil TDT but Im always looking for something better.
Old 01-04-2016, 02:40 PM
  #35
Quadcammer
Quadcammer's Avatar
I use my car year round, so based on my discussions with kevin and my usage, he recommended a blend.
I generally split 50/50 between the two. Additive pack appears to be the same so they are miscible without a problem.
Old 01-04-2016, 04:25 PM
  #36
RJKflyer
RJKflyer's Avatar
I use the prescribed Mobil 1. 997.2
Probably put in half a pint per 2,500 miles for first 10k (i.e. one bar drop from full), but it uses virtually nothing now at 16k.
And that's in spite of the blue smoke at start up!
Old 01-04-2016, 07:01 PM
  #37
Dennis C
Rocky Mountain High
Dennis C's Avatar
Received 1,547 Likes on 968 Posts
I haven't had to add any oil since I revived this thread last July, and I've had the oil changed once since then. I've driven about 3,000 miles in that time.
Old 01-04-2016, 07:30 PM
  #38
Dstutler
Dstutler's Avatar
NO oil consumption to note. Oil changed twice.
Old 01-04-2016, 07:41 PM
  #39
CincyScott
CincyScott's Avatar
And you even have the vastly inferior 9A1 motor!
I burn about a quart a year or 5000 miles. As Porsches go, I'm pretty happy with that.
Old 01-04-2016, 10:51 PM
  #40
DJ23
DJ23's Avatar
I never have to add oil between changes. My car doesn't burn any oil. Broke in the engine from day one with a different more aggressive approach. Hasn't failed me. The rings were set nicely with the break in.
Jay
Old 01-05-2016, 12:29 AM
  #41
ru'
ru''s Avatar
Bought my 997.2 almost 1 year ago, and got a litre of oil just in case. That litre bottle has remained un-opened...
Old 01-05-2016, 12:37 AM
  #42
elite1
elite1's Avatar
Quad, 50/50? 5w50/0w40? When you add that 1/4 qt, what are you adding, a mixture or straight 5w50?
I run Mobile synthetic 5w50. I only notice more oil burn during the obvious tracking situation.
  #43
nzskater
nzskater's Avatar
I burn a lot compared to others here - over a weekend of about 1000km of hard driving (very tight B roads, lots of 2nd & 3rd gear corners) I found the car needed close to 1L of oil. A decent track day will chew through 250-500ml. Car is on 120k km.
Old 01-05-2016, 12:48 AM
  #44
elite1
elite1's Avatar
Whoa! What grade of oil? That's a lot!
Old 01-05-2016, 02:58 AM
  #45
nzskater
nzskater's Avatar
Mobil 1 5w50. The service book states it can use up to 1.5l/1000km!
If I'm not pushing it will not burn much at all. In fact I barely have to top it up if I'm only cruising for long periods of time, but I tend to not let her get too relaxed between hoons
Quick Reply: What is your oil consumption?
