Option DAW
Option DAW
Porsche exclusive mentioned to me that option DAW included option DAD (Gear Lever/Handbrake in Aluminum/Leather) and CDZ (Leather Gear Lever Trim) as one package. Does anyone know the price of option DAW? They also mentioned that this would be the code to use if you wanted deviating stitching on both pieces.
I have both options and used 2 codes (DAD + CDZ). Not sure that DAW means both options but double check because CDZ is very important in order to get ALL stiching deviated around the shifter + it completes the look on the center console. Jason (Atomic) can tell you all about it. He is on CDZ patrol and will cite you for not getting it (for good reason). Good luck.
Are you thinking deviated stitching now?
Nope, I'm sticking with my plan. I just thought it was interesting that there was a code that apparently encompassed two codes in one and made it easier for porsche exclusive to code the deviating stitching on those options. Also, I wanted to see if anyone knew if the package price was less than ordering the two seperately.
