Wheel spacers, improve handling?
A wider track means more traction, so if you add spacer on the rear wheels your car would be more understeer, if you put on front, more oversteer. Thats why GT3RS has more rear traction than GT3 with the same tyre. For a TT, acceptable spacer about 10mm rear, 5mm front.
better than spacers would be to get wheels with a wider(smaller) offset. My GP7's give me the equivalent of an 8mm spacer front and 12mm spacer in the rear. Cooperlee has run 7mm front and 15mm rear H&R spacers for awhile now.
I run the same setup from H&R (7mm front, 15mm rear) with no issues. Car feels a bit more stable with crisper steering but some of that has to do with adding a bit more "toe" to the alignment in the rear and installing a front strut brace. New H & R springs to follow shortly ( about an inch and 1/2 drop). No engine mods and stock exhaust (for now). After struggling with a bad alignment from the factory and lowering tire air pressures to 33psi front, 39psi rear (cold) my car finally feels the way it should have right from the start.
I run the 7mm in front and 15mm in the rear as well with the H&R Springs. 25mm drop and it is great. Same air pressure setup as Gradyex. Hmm wonder why that would be
What's Erm.
You will appreciate the spacers if you are sticking with Stock Wheels.
http://www.6speedonline.com/forums/s...ad.php?t=93019
Pictures of my car with the spacers and lowered. I wish they made 10mm spacers for the fronts from H&R.
What's Erm.
Yes its definitly a car to drive with respect. i would just check the usual normal things that could be the obvious culprit like tire pressures, alignment (Porsche will spring for it under 2K miles). After that spacers seemed to help a bit (and its a relatively cheap mod easily removed). As soon as Alpines buddy gets back to me I already have a mechanic lined up to do the H&R springs so I can drop the car too. That should be the best mod for improving handling. The front strut brace didn't hurt either. I plan to stop right there (listening Alpine)? LOL later on this year (its almost booked up completely) I plan to do the 2 day Porsche driving experience. Here in SF CA, I found a nice little 1/4 mile side street leading to a large area that dead ends onto a vista point or lookout point (by the cliff house). When no one is around you can practice figure 8's , donuts, etc and just let loose without worry unless the police cruise in but they usually just tell you to get lost. Candelstick park (Monster Park) is a Porsche club favorite for setting up auto cross events with cones. Anyhow my point is take some time to learn this beast and what makes it tick. That won't solve any of these anamolies with the car but it will keep you from passing the point where the computer takes over. I must say its fun as hell to drive but I am comming from a 997S which had a different feel to it (more direct and linear).
Gradyex - Hey don't pick on me buddy! I have not tried to get you to ECU upgrade it - YET! Eric(springs) will call you today if he hasn't already. Just bug him again he is a busy fella.
why2nd - is that the first time you have pushed it when you felt it being a little out of control? It gets better over time with confidence and feel.. Dial it in just right with the right air pressure and alignment specs and you will want every corner that you can get your hands on.
Just broke it in at that time of post and yes, first time. Since that post I dropped tire pressure to 33 cold and that sensation has all but gone away. I'm still going to do an alignment asap...
Hi,
i have 15mm front and 18mm back from H&R (each side). It´s the only combination in germany with an ABE, which is very important in porscheland - otherwise you would have go to the public authority to check it...... or loosing insurance
Anyway, the car feels pretty the same and i like the look;-))
