Porsche factory Sirius in my 997TT
Thanks to Stephen, ImagineAuto, I now have perfect sounding Sirius radio in my turbo. It sounds great, works flawlessly and as designed by the factory. This was the finishing touch to make this incredible car even better. Thanks Stephen and your guide made it easy for the Porsche tech to do the install (he'd been asked several times to do the Cayenne install but was reluctant until now).
Rennlist Lifetime Member
You are very welcome! I am thrilled you like the kit. The Cayenne setup is what we start with but as you can see we modify the units to streamline the amount of wires and connectors. Almost plug and play!
Where do I sign up for my tt unit? I rephrase, is this unit oem looking clean no hardware hanging off ****..etc.
I had mind installed a while ago, instead of the Sirius unit hanging off the bulkhead, the dealer tech lay it flat on the floor of the trunk, cut out a high density foam the shape of the trunk floor and use it to surround the Sirius unit, and cover it all with the factory trunk floor panel. It was all hidden from view and pretty well protected too.
