997 Turbo Forum 2005-2012
ipod solution for 997?
Old Oct 25, 2007 | 01:18 AM
  #31
TT Surgeon's Avatar
TT Surgeon
Eric...............it worked! The old unit is on the way back, take back everything I said about denison. Must have been a bad unit. You really came through Eric!
CJH
Old Oct 25, 2007 | 01:47 AM
  #32
richk's Avatar
richk
this thread should be on the boxster forum
Old Oct 25, 2007 | 11:06 AM
  #33
TT Surgeon's Avatar
TT Surgeon
Maybe I spoke too soon...
Old Oct 25, 2007 | 05:22 PM
  #34
Eric - Plug Guy's Avatar
Eric - Plug Guy
Basic Sponsor
25 Year Member
Chris, I'm convinced there is some anomoly in your head unit (not in your head though). If it continues, have the head unit reprogrammed - this means the PIWIS tester (dealer) connects to the dash port, and they program the system as if they just added a cd changer. It reidentifies each node on the fiber optic loop, and that often solves these sorts of issues.
Keep us all posted. Thanks!
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring 6sp
2009 997 Turbo Cab 6sp
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Old Oct 26, 2007 | 12:49 AM
  #35
TT Surgeon's Avatar
TT Surgeon
I'm stopping by there in the am. Strange thing, when I first re-installed the new 'brain', everything worked great, 45 min into my commute, it just stopped, like it never had a cd changer port. On the ride home it was ok again. Tonight acted up again. hmmm.
Any ideas guys???
Old Oct 26, 2007 | 01:05 AM
  #36
eclou's Avatar
eclou
Chris it's time to get an ECU, drop the windows and listen to some real music
Old Oct 27, 2007 | 10:48 AM
  #37
Eric - Plug Guy
Basic Sponsor
25 Year Member
Any ideas guys???
My bet is the power connection is not right. Full straight unswitched power only, and also replace the Aux switch with the new one we sent.
Let me know!
Old Oct 27, 2007 | 01:27 PM
  #38
TT Surgeon's Avatar
TT Surgeon
How would I check that, the terminal where it plugs into the 'brain' seems snapped in tight?
Old Oct 27, 2007 | 02:34 PM
  #39
Eric - Plug Guy
Basic Sponsor
25 Year Member
Yep...just replace the Aux switch and cable with the new one we sent.
Power should be coming from battery, not fuse panel.
Old Nov 21, 2007 | 08:00 AM
  #40
W211's Avatar
W211
Eric, does the power must come from the battery? Mine is from the fuse panel and I'm puzzled isn't it safer connecting the Dension unit to the fuse box?
I'm still having battery drainage problem and here's what I posted on 6speed:
Ok, so I just checked my power source, it is exactly wired to the fuse unswitched, so I'm absolutely lost where it doesn't charge for that 2 hours, or whatever is needed.
Would like to find out from you all:
1. Does your iPod charge after you shut down the car? Mine immediately stops charging (after 10 seconds later).
2. I'm on 2.03 and I'm about to update to 2.05, hope it helps.
3. I notice that with my older iPod 3G 40G, the Dension kit often doesn't recognize it and I have to do numerous resets. However, I have no problem with the newer nanos.
4. Even with the more robust newer nanos connection, the nano still stops charging after car is shut off. Very puzzling.
Thanks for any feedback in advance!
Old Nov 21, 2007 | 09:21 AM
  #41
TT Surgeon's Avatar
TT Surgeon
FYI, I would NOT update to 2.05 if I were you, that's where my issues started( and continue). Eric has been very helpful, but it's (dennison)just not ready for prime time, imo. FWIW there ain't nothing wrong with the head unit in my car, that's like blaming the patient for a complication. GL
C
Old Nov 21, 2007 | 09:24 AM
  #42
atomic80's Avatar
atomic80
I would advise that you do try upgrading to 2.05. Mine works beautifully with 2.05 even to the point where it actually loads the song names, artists, etc. faster than before. It even fixed a small quirk that I had before where the ipod would sometimes reset itself. I haven't seen that happen since then.
Old Nov 23, 2007 | 08:34 AM
  #43
W211's Avatar
W211
Thanks Jason, so what iPod would you guys recommend (that is available at the Apple store now)? You see I'm so frustrated with the 3G iPod not working well that I'm willing to upgrade the iPod to try my luck again!
Old Nov 23, 2007 | 10:00 AM
  #44
997Vancity's Avatar
997Vancity
Eric any sale for Xmas with the Denison unit?
Old Nov 23, 2007 | 11:18 AM
  #45
atomic80's Avatar
atomic80
Eric,
I seem to recall the newest iPods having some sort of an encryption now that would probably restrict their use to approved Apple accessories. I'm not sure if this would render these iPods invalid with the Denison, Nav-TV, etc. I would advise that you look at those refurbished 4G or is it 5G iPods that they've got available now. I got one of those 80GB 4G iPod refurbished units and they work great. Have you also tried to see if one of your friends has a 4G unit that you could try out first?
