997 Turbo Forum 2005-2012
TPSM
Old Jul 9, 2007 | 09:13 PM
TT Surgeon's Avatar
TT Surgeon
Default TPSM
Anyway to bypass or shut it off yourself?
C
Old Jul 9, 2007 | 09:27 PM
Terry Adams's Avatar
Terry Adams
Veteran: Army
Don't know about the TT, but on my Lexus I can set the light to go on at any pressure I choose. I like it, though, as it already gave me fair warning of a slow leak from a nail.
Old Jul 9, 2007 | 09:34 PM
jhbrennan's Avatar
jhbrennan
C
No
Old Jul 9, 2007 | 10:23 PM
MMD's Avatar
MMD
Go to their website "beru.com" and find the Porsche application of their TPMS syatem. There's a few essays there which might explain if and how it can be done... .
Old Jul 10, 2007 | 12:21 AM
TT Surgeon's Avatar
TT Surgeon
Think I'll live with the idiot light at the track and have the dealer turn it off in the winter with my snows.
Old Jul 10, 2007 | 10:16 AM
jhbrennan's Avatar
jhbrennan
I'm not sure the dealer can even turn it off...or for that matter be willing to if they can since TPMS is an NHTSA / Tread Act "deal" now.
Old Jul 10, 2007 | 11:10 AM
MMD's Avatar
MMD
Interesting..., now that you mention it what happens if you finally run out of options and decide to remove or disconnect the TPMS receiver? My guess is you'll probably be stuck with a "TPMS Failure" warning on the dash.
Old Jul 10, 2007 | 01:11 PM
AAHTT's Avatar
AAHTT
You can't turn it off, the solution would be to buy another set of sensors for the track wheels. I did not and I live with the light at the track, actually I sometime live with a couple of lights at the track: TPMS, PSM OFF... they are not that distracting and once you flick the TPMS like while checking the tire pressure, the big triangle light goes away and you end up with only the red exclamation mark.
Old Jul 10, 2007 | 05:00 PM
mooty's Avatar
mooty
GT3 player par excellence
no one seems to listen to me. i have a cayman when it first came out, i posted everywhere to see if i can kill off the TPMS, to date, i have not seen any clever way to kill it off.
i tried PIWIS, no workie.
i am not cheap and i bought extra sensors for track wheels, but you know what, not EVERY wheelset will take the sensor... ugh......
so now i just ignore the light.
and if anyone ever find a way to turn it off elegantly (not just put a tape over it) PLEASE POST THE EXACT ALGORITHM ALL OVER 997, 997GT3, 997TT, 987 boards.
Old Jul 11, 2007 | 12:42 AM
PorschePhD's Avatar
PorschePhD
Rennlist Lifetime Member
Rumor has it there is a way to kill RDK. I am trying to get the info. There is a code that Porsche has and it will disable the RDK system. If and when I do find it I will let you know. The system still would need the PIWIS
Old Jul 11, 2007 | 03:04 PM
ALPINE_997's Avatar
ALPINE_997
I did this with my Lexus GS430 06MY. I put the sensors in a cannister(air tight) and pumped it up to 36PSI. - Used a rubber valve stem to pump the compressed air in. It took a while(2 days) for the sensors to read but it went away. I am not sure how the TPMS works on the Porsche 997's but if it is looking for a reading of Air Pressure from each sensor than that could work.
FYI - the reason for this method was because the sensor wouldn't fit without a metal band on the Rims that I purchased. So I had to come up with a solution to get rid of the warning lights.
Old Jul 11, 2007 | 03:51 PM
jhbrennan's Avatar
jhbrennan
If I understand this correctly, the TPMS receivers are in each wheel well so your cannisters would have to be close to each receiver. I have two extra sets of wheels in my garage with working TPM sensors and the car (while only 6 to 10 feet away from the extra wheels) only reads the sensors on the mounted wheels.
Old Jul 11, 2007 | 04:32 PM
TT Surgeon's Avatar
TT Surgeon
Sounds like a lot of hassle, guess either live with the light or buy some extra sensors. Anybody have an extra set?
Old Jul 11, 2007 | 11:05 PM
TT Gasman's Avatar
TT Gasman
How much are the sensors anyway? I had to replace a tire on my Expedition, I know it's not the same, but it's wheel sensors were cheap little things that just clamped on the valve stem. FWIW they were made by Bosch, so I wonder what the "Porsche tax" is on somethng like this?
Old Jul 11, 2007 | 11:15 PM
PorschePhD's Avatar
PorschePhD
They are about 55 each if I recall. I just set 4 of them in my new wheels and they were all 200.00 something.
These are a set with the valve stem. They screw to the back of them.
