Thick Smoke
Thick Smoke
Each time on start up when the car has sat overnight I get the most incredible thick blue belch of smoke out of the pipes.
Car starts well and runs fine!
I know they do this to some degree but the whole driveway is filled with smoke that lingers for some time. Anyone else have the same or some advice?
Not done 1000miles yet, perhaps this is part of run in?
TIA
TIA
I had the same problem with mine, used to start it up in the morning and thick smoke would come out of the exhaust. So I range Porsche up and explained the problem, and they said this was to be expected. I've had a few turbos previously, and I remembered that one of them had a similar problem, and it turned out there was oil in the turbo. So I spoke to Porsche again and explained my thoughts about there being oil in the turbo. So they opened up the turbo, and low and behold there was oil on one of them which was causing the smoke. So Porsche ummed and arrgghed cos it's an expensive warranty claim, but in the end they replaced the turbo and problem solved.
With your current situation. the smoke should stop when the oil temp reaches running temp, but this is not ideal when you're sitting in traffic with thick smoke coming out of your car :-).
Hope this helps
Lucas
Hope this helps
Lucas
I have just put my 997TT back into Porsche as it started smokign again from the right hand exhaust pipe.
The pulled off one of the pipes and 150ml of came out they reckon, They're really not sure whats causing this problem, but there's a lot of smoke coming out of the car until it reaches about 90 degrees running temperature.
Hopefully I will get some more info tomorrow. There's only 3000km on the clock, and they've just replaced the turbo, so there has to be elak somewhere that they aren't seeing
TIA
TIA
If it only happens during a cold start, no worries. It's just a little embarrassing (to be honest).
If the oil smoke continues to come out during cold running, then you may have a whole other issue.
My pipes are black soot which I think is normal.
I will have a word with Porsche as it does seem excessive.
My 996tt did a puff of smoke on start up but this is something the Environmental Agency would have something to say about!!!
Thanks for the info.
Cheers
Cheers
