RT12 at Silverstone national
Originally Posted by hesperus
brilliant!!!
by the way, how does she drive compared to your 993? i forgot to ask you about that...
quote
The suspension is very capable on track, perhaps a little more negative camber for all 4 wheels if you were to do more track driving than street (mainly only affects very high speed street driving) but it is a perfect compromise for street/track use the anti-roll bars are hugely capable and the shocks have very good travel and a nice progressive spring rate. Don't forget that critically this setup performs so well due to the 25pct extra torsional rigidity offered by the IRC (integrated roll cage) which acts more as a chassis stiffener than a typical FIA roll cage thus minimising chassis flex going through corners in particular where this enables the suspension geometry to be unaltered, the result is awesome and truly i would reccommend this to anyone before suspension modifications. The brakes again are more than up to the task, front discs are 380mm drilled and grooved with 8 piston stoppers, only upgrade i would reccommend are harder pads for track use but of course they will screach when cold which the stock ones don't. They generate immense stopping power and have a very sweet progressive bite for brake moderating.
all the best
leon
