997 Turbo Forum 2005-2012
997 Turbo re-post--hope not
Old 05-13-2006, 11:52 PM
gr8330
gr8330's Avatar
Default 997 Turbo re-post--hope not
I did a search and could not find this.
The 997 Turbo Tip has two dry clutches.....no slush box here. hench the blistering 0 to 60 times. I will say that I was fooled. I thinkl it's called DSG, please correct me if I'm wrong on the name
Old 05-14-2006, 05:34 AM
man_of_ice
man_of_ice's Avatar
DSG is Audis dual clutch system.
AFAIK (even though its basically something Porsche used in the 80'ies) its not available on any current models. Heard rumours about GT3's soon being offered with it though
Old 05-14-2006, 05:41 PM
gr8330
gr8330's Avatar
A person from PCNA told me Saturday that the new Turbo would have this transmission when it goes on sale in September
Old 05-14-2006, 08:12 PM
bpoteat
bpoteat's Avatar
Check out the june motortrend. Full test drive write-up on it, the type of transmission and exhaust. I don't have it handy, but the tester said that if they ever put PDK (porche's version of DSG) instead of Tip in this thing, the competitors better sell every single Ferrari and Lamborghini they can before it hits the market. That's how close to perfect this car is.
BTW, for $10 a year, motortrend is about the best auto-mag deal you can get.
Old 05-15-2006, 12:21 AM
gr8330
gr8330's Avatar
Thanks but I like C&D
Old 05-15-2006, 10:12 AM
bpoteat
bpoteat's Avatar
Are you limited to one magazine?
I read C&D as well.
Old 05-15-2006, 11:50 PM
gr8330
gr8330's Avatar
actually I'm not. Automobile, Excllence also
Old 05-16-2006, 11:25 AM
DCP
DCP's Avatar
The Road & Track article I was reading over the weekend said that the Auto was faster because the torque converter allowed you to spool up the turbos prior to launch. If accurate, it's a slushbox. A very fast slushbox, but a slushbox nonetheless.
Old 05-16-2006, 11:28 AM
Riad
Chandler!
Riad's Avatar
What's the definition of a slushbox?
Old 05-16-2006, 11:36 AM
earlyapex
earlyapex's Avatar
Porsche is not putting DSG in any of its production cars yet. It's all rumors at this point.
Old 05-16-2006, 12:36 PM
DCP
DCP's Avatar
A slushbox is a reference to a traditional automatic transmission; one which uses a torque converter. A torque converter transmits energy from the engine to the transmission by spinning turbine blades in transmission fluid. Think of a operating fan facing another fan which is off and the blades of the fan which is off turning. Needless to say, there are power losses in a slushbox.
At least Ferrari, BMW, Audi, and VW are now offering manual transmissions with electonically activated clutches and gear changes ala F1 cars. These can be operated as automatics. Porsche has not offered one, and I don't think the 997 Turbo has one. The fluid connection in the torque converter will allow you to rev up the engine a bit with your foot on the brake to keep the car from moving giving more boost. Thus the slushbox 997 Turbo is quicker 0-60 than the manual.
Old 05-16-2006, 01:09 PM
Riad
Chandler!
Riad's Avatar
Cool thanks.
Old 05-16-2006, 07:27 PM
gr8330
gr8330's Avatar
You guys are making me wonder why this guy from PCNA would say that if it isn't true. Any one know Terry Wells?
Old 05-16-2006, 08:47 PM
DCP
DCP's Avatar
Default We really have no idea, just going on what we have read
This is from AutoWeek:
Yes, the Tiptronic is faster than the manual. Porsche says improvements made to the Tip’s hydraulics allow for brake torquing on takeoff, letting the turbos spool up and deliver full boost pressure immediately. It’s faster in passing speeds, too–if only by a hair–because gearing in the Tip is such that the turbos maintain full boost pressure throughout the rev range rather than dropping off slightly at shift points.
Brake Torquing is (Google):
A procedure generally used in performance tests to improve the off-the-line acceleration of a car equipped with an automatic transmission. It is exectued by firmly dpressing the brake with the left foot, applying the throttle with the car in gear to increase engine rpm, then releasing the brakes. Brake torquing is particularly effective with turbocharged cars because it helps overcome turbo lag.
From modernracer.com:
This launch involves keeping the car stationary by flooring the brakes with the left foot, while using the right foot to rev up the engine against the torque converter.
The technique has this nagging problem (same site):
There is a lot of stress on the transmission, and the consequent heat build-up can destroy your automatic gearbox.
So, it does appear to be a traditional automatic. Maybe its was PCNA hoping for the other box. Who knows?
Quick Reply: 997 Turbo re-post--hope not
