997 Turbo Forum 2005-2012
suspension upgrade thoughts
Old Nov 27, 2023 | 04:20 PM
tonupbklyn's Avatar
tonupbklyn
Default suspension upgrade thoughts
any owners have gone any of these similar sequence of upgrades...and have noticed significant (positive) differences after each step?
stock --> +DSC --> +lowering springs --> +coilovers --> +sway bars
stock --> +DSC --> +lowering springs +sway bars --> +coilovers
stock --> +DSC --> +lowering springs --> +coilovers +sway bars
stock --> +DSC --> +lowering springs +coilovers +sway bars
i have just the DSC at the moment...and contemplating whether to go next step with just lower springs or go full monty right away.
this will be 100% for street, no track.
Old Nov 27, 2023 | 09:57 PM
Rig.Stunts's Avatar
Rig.Stunts
Define positive!
More comfort, or more body control?
Lowering springs are negated by coilovers, which will have ride height adjustment.
Swaybars will improve body roll, but transmit 'bumps' to opposite wheel.
DSC will soften OE dampers during low G force driving. But to realize the real positives of the controller - fast damper change - Tractive dampers are required.
Also an alignment for performance should be considered.
Enjoy!
Old Nov 27, 2023 | 10:19 PM
tonupbklyn's Avatar
tonupbklyn
Originally Posted by Rig.Stunts
Define positive!
Enjoy!
good lord, man... you're not helping!...ha!
agreed, 'positive' could mean different things to each person.
i also assume that any of the mechanical mods I've indicated above are not going to equate to a more "comfortable" ride... rather, a more "compliant" one.
i don't drive around town in the pcar. it's mostly/entirely Sunday rides on windy roads and highway around my neck of woods (Westchester and CT, for those who know the NY area of US)... fairly smooth pavements.
with that in mind, with already having DSC, do i go a first step with lowering springs only, or go full hog with the additional components I've noted?
Old Nov 27, 2023 | 11:05 PM
IHTFP's Avatar
IHTFP
If you haven't done this already, I would also consider new RS hardness bushings all around.
Old Nov 28, 2023 | 01:44 AM
changster123's Avatar
changster123
I would go straight to full coilovers, kinematics, sway, corner balance.
I have the above with Tractive RTx’s on 110Nm/150Nm springs which is supposed to be the track spring rate. With good dampers you should not worry about being too overly sprung. Sometimes I wonder if I need even stiffer springs because it’s so compliant. Compliant meaning it is stiff with fantastic platform control but absorbs all the bumps with ease.
My 997.2 Turbo S handles like it’s on rails. It’s also very very compliant on the street. This car sees both track and street duty. To be honest the feel like I can never go back to any OEM suspension on any car except the daily family SUV.
Old Nov 28, 2023 | 11:18 AM
MV911T's Avatar
MV911T
Some KW coilovers, swaybars and corner balance. It will be a different world after that.
Old Nov 28, 2023 | 01:00 PM
wcarson's Avatar
wcarson
I have DSC, GMG lowering springs, and GMG swaybars. Street driven only. I’m very happy with my set up. It’s certainly less expensive than going with a full coil over conversion.
Old Nov 28, 2023 | 01:09 PM
charsiuboar's Avatar
charsiuboar
Are folks putting lowering springs on OE (PASM) dampeners? Doesn’t that cause accelerated wear and/or potential for blowing out the internal pistons?
Old Nov 28, 2023 | 01:18 PM
tonupbklyn's Avatar
tonupbklyn
this combo (different mfr) is where my head is... but what I'm curious to know from other owners is going from this setup to then adding coilovers, is that a massive difference? or is this basic setup w/o coilovers pretty much equivalent?
Old Nov 28, 2023 | 02:03 PM
Rig.Stunts's Avatar
Rig.Stunts
Upgrading suspension is not easy, but rewarding!
Consensus is DSC with B16 coilovers, and an alignment. Keeps PASM. DSC box performs at reduced potential.
Adding Tractive coilovers with appropriate spring rates, and an alignment is your deluxe solution. Replaces PASM
Sways without LCAs and aggressive alignment is a waste of money that will unnecessarily reduce street compliance.
Sell the controller, and go Ohlins or KW coilovers - brilliant, well sorted. Loses PASM. This sets you up to enter the 'full send' path - front LCAs, sways and much, much more. Folks may say this is only for track, I disagree, it works amazing for street. Though you will lose all 'daily' enjoyment. Degrades resale value . . .
Having fun yet?
Old Nov 28, 2023 | 02:32 PM
tonupbklyn's Avatar
tonupbklyn
dsc+springs vs dsc+b16...how big a difference between the two? "holy cow, night/day difference!"...or more like "eh, it's marginally better"?
Old Nov 28, 2023 | 03:23 PM
Rig.Stunts's Avatar
Rig.Stunts
I'll guess marginal . . .
The Holy Cow moments happen with increased front track and increased front negative camber
Old Nov 29, 2023 | 04:17 PM
tonupbklyn's Avatar
tonupbklyn
i think i'm headed toward b16s and steel brake lines.
question is do i add thicker sway bars now...or give this setup a go for awhile?
Old Nov 29, 2023 | 11:20 PM
Rig.Stunts's Avatar
Rig.Stunts
Save sways for later stage tuning.
When lowering you may have to deal with geo changes. This may mean more shiny bits . . .
Adjustable front LCAs next for the win.
Old Nov 30, 2023 | 05:37 AM
Ruri's Avatar
Ruri
I drive in the SoCal canyons half the time then other half is driving to car meets or around town.
I did the DSC first and this mod kept me from selling the Turbo.
then I changed the rear way bar and bushings to the GT2 OEM one.this made the tail end rotate out a little more on turns and eliminated the pushing.
i ordered some Tarrett sway bar links, Bilstein B8s, and I’m waiting on a set of spring. I ordered these last parts during Covid and they have been coming in batches.
I’ll report back how this setup feels if I can ever get it on.
During this last part of this project I picked up a 997.1 GT3 and lost interest in the Turbo. The handling compared to my current Turbo setup is leaps ahead of the Turbo in the canyons. I can effortlessly add 15-20 MPH in the same turns as my Turbo.
