Does the switch press and hold from the 996 work the same on the 997 for the window memory reset? My passenger window does not auto up / one touch unless half way up already.
Sounds normal. Mine's done it that way since new. Safety feature if you have a kid in the passenger seat.
Your 997 does that? It's not normal; passenger window should go all the way up if you pull the switch to the auto-up notch. The window reset procedure OP mentioned should resolve it. (I don't recall the exact procedure, but it involves holding the switch after the window is up; a quick search of the forum should find it.
Maybe its a .1 // .2 thing?
Originally Posted by nzskater
Mines always behaved like that. Needs to be held to halfway then closes after release
I'm now interested in hearing from more people, I would think if it was normal that kind of info would be easy to find no?
Just tried that and it does not reset to one touch all the way up. Only goes all the way up when just past the half way up.
I didn't think to look in the manual... duh... That settles that. Thanks!
No problem. When I got my Turbo I thought the window behavior was strange so I checked the manual and to my surprise, it showed that this was the designed operation. I can’t figure out how this is a safety feature. What is the potential incident that it is trying to prevent from happening?
