Another Slave/Accumulator Failure
Stick with OEM slave/accum replacement
- I personally don't like the pedal feel - engagement point is not ideal
- I don't want another failure. Car has 50k miles and it's the first failure but it's not a DD like the original owner used it. Is that a potential reason the slave failed - lack of driving?
- Keeps the system stock (have EP1 + UMW tune so...not a big concern)
BBI
- Looks to be the easiest conversion to install. Also appears to be high quality.
- Pretty spendy....
- I've read issues where the master cylinder, BBI slave and various lines have failed after the install due to some mixing of pentosin & DOT 4. Is this a risk with BBI?
- Heavier more direct feel of the pedal, along with the GT2/3 clutch assist spring
EVOMS GT2 Conversion
- Using OEM components seems like a better route to go - and no tapping of the housing which is good
- Again has a heavier more direct feel of the pedal, along with the GT2/3 clutch assist spring
- Kit comes with braided lines, new master, clutch assist spring, etc. IMO this almost eliminates the chance of mixing fluids IF the EVOMS kit requires DOT 4.
- More labor intensive to install?
So in reality for me it's between BBI or EVOMS. It's not a daily driver and I'm a larger guy so I have no issues with a heavier pedal - but will opt for the GT clutch assist spring regardless.
Any thoughts from those who have owned or driven each? I have the stock clutch BTW. Any other suggestions or things to look out for?
BBI
- Pretty spendy....
Either way both kits can be done with the transmission in the car and if you are going to go with the BBI slave I would suggest changing the master just so there is no issue with fluid.
Biggest problem with the BBI is that if the seals inside fail you have to send the slave back to BBI and have them replace the seals they will not sell them to you.
Going the gt2 route if it fails order another 100 slave and have it done in a couple hours, I also like that the gt2 just blocks of the ports for power steering less areas that could leak.
You said you tapped the housing - I assume you didn't use the EVOMS kit, you actually just converted the GT2 setup from the get-go? I believe with the EVOMS kit there's no tapping needed - or am I incorrect?
Had a shop do the EVOMS install and it went less smooth than hoped, had a clearance issue with the bracket not fitting snug against the transmission, but got great support from EVOMS. After slightly dropping the trans, the issue was resolved with very minor grinding of the bell housing, Anyhow, love the GT2 pedal feel compared with the stock setup.
Way I see it each setup has some kind of compromise except tapping the bell housing in the correct gt2 oem location, but that is an involved process from what I've read.
- Drop Transmission
- Drill and tap is easy for a shop that has done it before,
- New GT2 slave,
- New GT2 reverse clutch fork.
- New GT2 line,
- New GT2 clutch pedal spring,
- Flush/re-use existing master cyl.
- Un-couple clutch circuit in power steering pump.
I thought I probably needed a slave cyl replacement so thought I'd get the BBI slave to also improve the clutch feel. There are a couple of tests that you can do to narrow down whether it is the accummulator and/or slave cyl. I don't recall the exact tests but if you start the car after letting it set a few days, and thn pump the pedal counting when the pedal becomes stiff. If it gets very stiff before 15 pumps, you likely have a bad accumulator. If the slave is bad you'll either have a leak in the right rear or at the clutch reservoir.....possibly right at the slave and PS reservoir will be low on fluid.
I thought I needed a slave cyl bc of the terrible and inconsistent clutch action as well as occasional stiff pedal.....but I didn't have any leaks.
Along the way I noticed that I needed to replace the motor and transmission mounts bc they had deteriorated, so i did this before tackling tge slave cyl. After installing the mounts, the clutch action was much much better, and for whatever reason, the clutch pedal vagueness and stiffness was drastically improved....no other changes.
I suspect that the clutch pickup point was affected by the sloppiness in the motor and transmission mounts to the point that the driveline was actually displacing under load (letting out the clutch) and causing the inconsistant pickup point.
Currently my clutch pedal will stiffen as I approach ~ 20 pumps, so at some point I may need to replace the accumulator and possibly a slave cylinder too. But for now, it is a much better driving experience.
The motor mounts are an easy install and parts are less than $300. The transmount is a little more involved but there are some great dyi on the site. I chose to replace the entire trans mount and added some upgraded easily dropped in aftmkt bushing stiffening inserts from Function First...approx $500 for oem mount and inserts. ALSO used the Function First semi-semi solid motor mounts to keep nvh to a minimum.
Right now just trying to line it all up to see if it makes sense. I need to drive a car with the swap in order to really see if it makes sense for me. Otherwise keep the stock assisted setup (obviously repair it). If I do a swap, as pfbz suggested, I'll do the full GT2 swap - no kits. So drop the trans tap it, and so on. This then begs the question - what else do I do once the trans is off the car....?
