997 Turbo Forum 2005-2012
Update ignition coil
Old 12-02-2018 | 11:56 AM
Johnny DB's Avatar
Johnny DB
Originally Posted by atcbi5
👍that’s how you do things, great job.
Just following Kevin's advice from a while back!
Old 12-07-2018 | 02:11 PM
Turboslut's Avatar
Turboslut
I just went with this scew where it was getting in the way...
Amazon Amazon
Old 12-07-2018 | 02:33 PM
gmsracing's Avatar
gmsracing
I just did mine ('10 tt) and got the OEM parts from Suncoast. They fit fine.
Old 12-20-2018 | 05:29 PM
Cubes's Avatar
Cubes
different engine my friend.
Old 12-23-2018 | 12:44 AM
pfbz's Avatar
pfbz
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You probably at least want to use a flange head bolt rather than a countersunk head bolt...
I've used motorcycle-style flange head bolts which have a MUCH smaller head than the reverse-torx bolts Beru provides...
These would provide even more additional clearance...
Amazon flanged button head Torx Bolts Amazon flanged button head Torx Bolts
Old 12-29-2018 | 01:54 PM
Johnny DB's Avatar
Johnny DB
I agree above the bolts mentioned above!
Old 12-29-2018 | 01:56 PM
Johnny DB's Avatar
Johnny DB
Did my plugs and coils over Xmas...glad I went with Kevin's recommendation and used the "older" thinner coils! The worst plug/coil to do (at least for me) was the front driver's side...
Old 12-29-2018 | 06:19 PM
ECB's Avatar
ECB
I agree. The only way I could get that one was to drop the engine a few inches.
Old 12-30-2018 | 03:45 PM
Lordbizness's Avatar
Lordbizness
Just putting this out there, I did the same on my car a few weeks ago. I used the skinny coils for the fronts and the "newer" design in the middle and farther banks. No issues at all.
Old 01-02-2019 | 12:38 PM
tinkerbill's Avatar
tinkerbill
Is the engine lowering procedure necessary on the 997.2 and if yes, can someone point me to a written procedure for doing this please?
Bill
Old 01-02-2019 | 03:58 PM
ECB's Avatar
ECB
Bill
I've heard the .2 plugs are easier to get to. This was the tough one for me:
Attachment 1348247
Old 01-04-2019 | 11:42 PM
911.Forever's Avatar
911.Forever
Plenty of seasoned veterans have offered great advice here. Use the correct, thinner "matched" coil packs or you had better own stock in Tylenol. I dropped the engine 3cm to ease access to the drivers side coils and plugs. You can barely see the front and second coils in the photo (blocked them with the coil and my hand). But they were no problem at all to swap out with the engine dropped. I did not back the engine mount nuts all the way off. I also pulled the O2 sensor for super easy access. PS: the car is on my lift - by far the most indispensable tool in the garage.
Old 01-05-2019 | 12:02 AM
911.Forever
Bill
I've no actual experience with the .2 TT but have read several blogs that indicate the .2 is a much easier job to tackle. Also read someone's comments (paraphrased) that Porsche engineers to this day circle around their topped up steins and joke about creative engineering wizardry (translation: DIFFICULTY) crafted into the 997.1 spark plug/coil access. Of course the .2 eliminated many skinned knuckles.
Old 01-09-2019 | 04:37 PM
Johnny DB's Avatar
Johnny DB
Also disconnecting the hose attached to the driver's side inlet duct (as per the Rock's instructions) helped a lot to be able to move it at the turbo.
Old 06-12-2020 | 10:08 PM
Daffy113's Avatar
Daffy113
Where did you purchase them? 997-602-104-01 seems to be unavailable online. Thx!
Quick Reply: Update ignition coil
