HELP! thoughts? Rodent damage/ engine drop
Son with a 2007 911TT and wife with a Mini both had their cars outside at their house.
The mice got the wiring harness on the Mini, but left the TT. Go figure.
Originally Posted by mffarrell
Coolant pipe fix
Expansion tank
Water pump
Check valves
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Throttle body seal
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount
Multi-rib belt
Expansion tank
Water pump
Check valves
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Throttle body seal
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount
Multi-rib belt
^ Interesting that the dealer just rolled it out to the parking lot without the engine in it.. at least they put the support brace back in before moving it..
Engine harness must be a long lead time item and they didn't want your car taking up a valuable lift
Looks so high with no weight back there. Are those 991 wheels?
Sad day... stopped by porsche and saw my car missing a few parts😢
Attachment 1296531Attachment 1296532
