Rear "Spoiler Control Failure" message HELP
It will go up but not down automatically (periodically). Sometimes the manual switch works, other times not.
It looked like it was the upper limit switch that wasn't registering. I broke the switch getting it out and so couldn't confirm this guess. I replaced the switch ($45+) and confirmed both switches operational. No effect on the fault.Is there a way to trouble shoot the control module?
I have both PIWIS and Durametric.
Thanks in advance for any help here.
MK19
MK19
Basic Sponsor
Yep... those pesky little micro switches. Fill it back up with fluid. Lots and lots of posts about that procedure if you search.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
