997 Turbo Forum 2005-2012
HPDE Prep
Old Aug 8, 2018 | 11:20 PM
07 Turbo's Avatar
07 Turbo
Default HPDE Prep
Going to Road Atlanta for my second HPDE event. Next week will be prep the car; brake bleed, check tires, wheels, brakes and coolant. Got a few questions on oil and what to change out:
1. Change engine oil, going with Mobil 1 5W50, should I go with Mobil 1 5W-50 Synthetic Oil or?
2. Should I change the Tiptronic and front diff oils also? If so any suggestions on which oil to use?
My turbo is a 2007 and only 11,500 miles.
Old Aug 8, 2018 | 11:51 PM
JG 996T's Avatar
JG 996T
1. That’s good.
2. Delvac but probably not needed yet.
Old Aug 9, 2018 | 08:11 AM
pterwilliger's Avatar
pterwilliger
I suggest also changing your Tiptronic and differential fluids. Although your mileage is low, you need to consider the shelf life of the fluids in the car. If not changed previously, you’re looking at 11 yrs on the original fluids. These track days put a lot of added stress on the transmission, and a fluid change wouldn’t hurt. I recently took my new to me 2010 out for my first track day with the car and changed all the fluids in advance.
Old Aug 9, 2018 | 09:23 AM
Quadcammer's Avatar
Quadcammer
Mobil 5w50 is fine
I'd change the powertrain fluids, but Its probably not necessary if its your second ever event.
More importantly, are the brakes in good shape, what pads are you running, and what brake fluid.
Old Aug 9, 2018 | 11:16 PM
07 Turbo's Avatar
07 Turbo
That's what I was thinking, the tip and dif have never been changed and it's going year 11.
Old Aug 9, 2018 | 11:22 PM
07 Turbo's Avatar
07 Turbo
Originally Posted by Quadcammer
Mobil 5w50 is fine
As far as I know everything is stock except for the mod's that I went for. As for brake pads Im thinking on swapping those for the Hawks on my next DE in Oct. which is at Barber. As for fluid I was going to go with the Blue DOT (?)
Old Aug 10, 2018 | 01:47 AM
nzskater's Avatar
nzskater
Consider Castrol SRF, is great.
Old Aug 10, 2018 | 02:03 PM
Quadcammer's Avatar
Quadcammer
srf is great but kinda overkill.
I'd look at PFC pads and consider Motul RBF600 fluid
Old Aug 10, 2018 | 03:38 PM
cstyles's Avatar
cstyles
1. Fresh brake fluid and upgrade to a 600F DOT4 fluid considering you're flushing the fluid anyways
2. Consider some better pads than OEM. Pagid RSL29 are a good blend of performance, durability and cost especially if you're not running in the advanced groups (which if this is your 2nd DE, I suspect you're not)
3. You owe it to your self and the other people sharing the track with you to not show up running coolant unless your coolant fittings have been addressed; flush coolant and replace with distilled water + 1 bottle of Redline's WaterWetter. It's dirt cheap and only takes your tech an hour so there is no excuse for running coolant at the track. PCA UCR chapter here in Toronto mandates either pinned / welded pipes or waterwetter in any GT3 or Turbo with Mezger motor. A coolant line can fail anywhere at any time, regardless of skill level or group you're in. I personally run the water + WW as I don't have my fittings addressed and the car actually runs cooler than with coolant
4. Take a good attitude to the track, the 997TT is a lot of car for any beginner or intermediate driver! I know from experience as I also started tracking when I got my 997TT two seasons ago. I've just acquired a 2006 fully prepped & dedicated Cayman S HPDE car as I am at a level where it was time to make some major modifications to my 997TT to make it safer at the track, or buy a tool dedicated to the job. Went with the new tool option, who doesn't love a new tool
Have fun! 997TT's are awesome cars at the track and a ton of fun!
Old Aug 15, 2018 | 08:56 PM
pfbz's Avatar
pfbz
SRF is expensive compared to other brake fluids, but still pretty dang cheap as a performance upgrade. ~$55/liter, and 1 liter should be enough for a complete flush.
IMHO it's perfect for street cars that do occasional DE's, as not only does it have a high dry boiling point, but it will still perform great when not completely fresh with a high wet boiling point.
Old Aug 15, 2018 | 10:07 PM
nzskater's Avatar
nzskater
Agreed. In the scheme of things it's a relatively low cost safety item.
Old Aug 16, 2018 | 12:13 AM
512bb's Avatar
512bb
Agree with all the suggestions. Road Atlanta is a bit unforgiving should anything go wrong, I would also check all the suspension points and make sure they are torqued correctly. I would change all the fluids and check to see that they are in good shape (i.e., no metal shavings, etc.). Finally, if you run 5-50 weight oil, make sure that you warm up the engine before gunning it and have fun.
Old Aug 16, 2018 | 01:14 AM
pfbz's Avatar
pfbz
...and don't forget to completely empty your frunk, remove anything not secured inside the cabin, and pull the drivers floor mat.
Old Aug 25, 2018 | 05:14 PM
07 Turbo's Avatar
07 Turbo
Thanks for all the input. Putting her on the rack tonight to start my track prep; changing brake, oil, trans and diff. I need to do some research on the coolant, never heard of the wet water however I do have track etiquette always thinking who's on track with me:::: be responsible and pay attention.
Old Aug 25, 2018 | 08:00 PM
cstyles's Avatar
cstyles
Amazon Amazon
Just one bottle + distilled water, that's it. Car runs noticeably cooler as well, compared to coolant. In the unfortunate event of a coolant leak on track, the distilled water + water wetter does not have the lubricity of coolant. It's virtually the same as just water being dumped onto the track, and much less of a potential for catastrophe if your rear tires get into it or someone behind you goes through it.
Our local PCA chapter has 1-2 coolant dump events per season. Not a guarantee it will happen of course, but the distilled water + water wetter combo is so cheap and easy there's just no excuse. Have fun and make sure the wheel is pointed reasonably straight when you bury the go pedal!
