Cheap boost leak tester for the 997 Turbo
So I've been meaning to pressure test my intake tract on my 7TT.
Realized it was super easy when I had the rear wheels off this past weekend. I measured the compressor outlets and headed to Homie Depot for some parts.
Here's what you need:
1 1/2" Sched 40 PVC Plug
1 1/2" x 1/2" Sched 40 PVC Reducer/plug
1/2 to 3/8 brass reducer nut
1/4" male air fitting (has 3/8" NPT thread)
I measured the spouts on the turbo compressor outlets. Theres a groove that needs to be filed/ground/cut into the PVC fittings so that they won't get shot out of the hose under pressure.
I used a small lathe to turn a 5mm wide x 1mm deep groove 7mm from the end of each PVC fitting. These dimensions mirrored the spouts on the turbo. You could probably do this with a file.
Here's some pics that show you the completed pieces:
I put a plug on each charge hose and used regulated compressed air to start pressurizing the system. I started at 10 psi and worked my way up to about 25psi (the gauge reads high as the valve is closed in the pics).
I did learn that one of my Norma clamps that secures the intercooler hose to the turbo was not able to be fully tightened and would leak at just 10 psi. I put a new clamp on and found no other leaks.
Job done. Much easier than expected and only cost ~$10 in materials.
Hope that helps someone.
^ Very nice work, If I didn't already have a set that I got from Markski (I like yours better, BTW) I would build these..I have to use 2 hose clamps so that I'm absolutely sure the plug is in.. I had one come out at 12psi once before and it scared the crap outta me :-)
I bet you could make a bunch of these and sell them to fellow RLers..
Thanks! I've got no interest in manufacturing/selling -- too many other projects.
While having a lathe made this a breeze, I think you could easily do it with just a file. If you've got a drill press or a Dremel, you could also likely make something workable. PVC is pretty soft, and the groove is only 1mm deep, so material removal is pretty quick.
Basic Sponsor
I borrowed a set from a friend, no groove. Will be interesting, hope it doesn’t blow off and take my eye out.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Just don't put your face anywhere near it. I have a similar setup to use on my Audi turbos, no grooves, testing to about 20 PSI and no blowouts, but they can and do happen. So pay attention to the direction they could blow and make sure nothing fragile, like your face or hands, are in the way.
Thanks for the info, makes it easy to mock a set of these up for testing, and with turbos, leakage is a killer.
Ed
Ed
Basic Sponsor
A few wraps Gorilla tape (or similar) around the fittings and a few strokes with sandpaper to rough up the tape makes them much less slick and less likely to pop out. It definitely WILL get your attention if one blows out!
Truth be told I did have a blowout at ~15psi with the faulty Norma clamp -- the clamp would only tighten so much before the worm would skip teeth on the band and tighten no further.
As I was standing behind the car when it happened it wasn't full code brown, but it definitely got my attention. Eye pro and/or a face shield is highly recommended.
In my case the fitting that slipped was the one in the picture with the air hose on it (and the non-factory clamp). As such, it was quickly arrested by the weight of the hose and didn't fly around the garage.
Also, if you're going to do this job, you may consider pre-ordering some additional "Norma 40-60 x 9mm" clamps -- [NORMA 01266704050-000-0541]. These clamps sit right behind the rear tires and get a little mangy. I found a guy on Ebay selling 6 clamps for ~$8 shipped. At that price they're good spares to have, not just for Porsche -- lots of European cars use them on cooling system hoses.
One other quick thought: If you're running factory intercoolers like me, do not go crazy with the test pressure. I heard some faint creaking noises from the intercoolers as I got up around 25psi and it spooked me. It's probably best to only test up to your max boost pressure or maybe a few psi higher. My guess is that 20psi is plenty high for folks on stock ICs. I don't want anyone blowing off an end tank.
