PCM upgrades
PCM upgrades
Long time no speak gang, hope all is well. I’m interested in upgrading my PCM. There’s a catch, however... I want it to look stock. Can a 997.1 PCM be upgraded internally to have additional functions or a touch screen? If not, can the 997.2 be retrofit?
I know, there are lots of aftermarket options, I’m just not keen on aftermarket looks. Thanks!
There's a lot of information in this thread from 6 speedonline regarding PCM 3.0 retrofit on 997.1tt
https://www.6speedonline.com/forums/...sion-done.html
It's a lot of work to get everything installed and working properly. This has been done by a few people and this is something I would love to do to my 997.1 as well...
Rocky Mountain High
I added a MObridge system to my OE PCM 2.1 in my 997.1 turbo. It looked perfectly stock, with the only exception being a small mic mounted on the windshield up by the rear view mirror. This added Bluetooth streaming audio, as well as Bluetooth telephone connectivity. I was able to use the OE phonebook to make calls, and incoming caller ID showed up on the PCM screen. Calls were answered using the OE phone buttons on the PCM unit. It didn’t have a satellite radio connection, but I was able to stream Sirius XM through the Bluetooth connection using the Sirius XM app.
That’s the closest that I have found to an upgrade that retains the OE look, and doesn’t add additional controllers or buttons to the cockpit.
There is not other alternative which looks stock.
Rocky Mountain High
I wouldn't say that MObridge is perfect, by any means. That said, it worked flawlessly for me over 95% of the time. When there was an occasional glitch, it was resolved by turning the ignition off and on again.
I had similar goals to yours; I wanted my system to look as close as possible to an OE system. I didn't really care about a modern nav update as I hardly used the OE nav and it worked fine when I did.
As mentioned above, you could install a newer PCM 3.0 from a 997.2 car. It's an expensive process and it requires lots of work. PCM 3.0 is outdated too, so I'm not sure you'd gain much.
I think that other than a system like MObridge or Denison, your best bet is a complete replacement with a modern head unit.
Rocky Mountain High
I don't know if these systems are good or not, but I'll throw this out there too:
http://www.dynavin.com/products/n7_ps_s.php
Here it is in a Cayman:
Interesting. Had a look at the video - the plus is that it actually looks OK for an AM product. The major downside is that the interface looks ugly and slow to respond to input. Personally I'd rather a slightly buggy Bluetooth add on to the PCM than an AM unit that has a ton of features I'll never use.
I have a Dension, have a USB cable running under the door seal up the A pillar and a NKMOS Ultima phone pad at the top of the windscreen. The Dension does what I need 95% of the time, and when it doesn't I unplug and replug the USB cable which takes all of two seconds.
