Bradan 997 turbo engine service
Former Vendor
This 997 turbo had very low mileage and developed a misfire. The variable valve timing system became clogged and would not advance timing causing a misfire. When removed we found the collar around the camshaft spun. We were able to spin the collar and press a pin in place to prevent this from happening again.
Photo showing pin in camshaft.
