Paintable Side Skirts
I've done quite a bit of research, exercising the google, rennlist and 6sp** search buttons. Information is kinda spread all over the place, and I can't seem to find a definitive answer to my ultimate question.
Here's what I know:
The earlier 997 GT2 paintable (primed) OEM side skirts are discontinued. Can't find them anywhere.
Those GT2 side skirts were used as replacements/mods to 997.1 widebody cars, including my 997.1 TT.
The 997 GTS had a similar or perhaps identical side skirt to the GT2. The GTS is a widebody configuration.
The GTS side skirt (primed) part number is 997-504-982-82 (right side). Similar number for left.
I have read that ALL wide body 997s have compatible side skirt mounts for factory options. I can't personally verify this.
I'm not interested in the matte black, non-paintable skirts. Nor non-OEM skirts. Nor the "basic" or standard skirt.
What I want to know:
Is the the GTS part number 997-504-982-82 compatible with the 997.1TT?
Is it essentially the same as the GT2 side skirt (discontinued)?
Thanks to anyone with explicit knowledge on this.
Cheers,
John
PS: I think I'll cross post on the busier 997 forum as well.
Here's what I know:
Cheers,
John
Close, but...
Thanks for the quick Ebay link. You're on the right track. But I believe that item is the "basic" side skirt, although in the paintable finish (instead of matte black). So that is the equivalent to the currently available Suncoast item:
Suncoast 997 Paintable basic skirt
I believe I'm looking for the GT2 styled skirt which adorned the GTS, and is available today as an OEM primed/paintable part. See for example:
Sonnen Porsche - 997 GTS primed skirt part
Just to reiterate, the standing question is whether the referenced GTS part (see Sonnen link above) is compatible with all 997 widebodies, in particular 2009 997TT.
Answered your post in the 997 section but answer to both questions is yes.
I just did this. You don't need the version with primer. Any body shop can prep the prep, prime, and paint. I purchased this non-primed version of the GT2 side skirts from Suncoast and my body shop took care of the prep, prime, paint, and install: https://www.suncoastparts.com/product/GT2SILLTRIM.html (FYI, my car is a 997.2 but the part about not needing the factory primer holds true)
OK. So that's a new twist....
Few questions:
- Is the referenced Suncoast black part the same polyurethane material? I assume so.
- Isn't the finish a satin or slightly textured? Assume this requires a sanding at least to take it down before any primer or paint application.
- If the Suncoast black piece is ~$760 (+ship) and the primed GTS skirts are 2x$409 = $818 (+ship), then wouldn't it make sense to spend the +$58 to avoid the extra prep/sanding and priming?
The Suncoast parts are OEM Porsche parts. They are the identical gray dark plastic (poly?) included from the factory because these are factory parts. The GT2 skirts are slightly more $$ because they are for the GT2 and Porsche charges a premium. IMO they do look better than the factory skirts but if you want to retain the original look, go with the GTS skirts. The GT2 skirts are likely a few more dollars at the end of the day due to the extra prep (as you stated). They are smooth material but they do need prep for the primer and paint to stick. As a 3rd option, you can get the original OEM skirts with primer for $999 for a set of two: https://www.suncoastparts.com/product/997TTPPS.html (These may be 100% the same as the GTS skirts, not sure).
