A change of winter hibernation plans?
Hi all, we have salty roads here in UK from Nov-Mar. I’ve winterized my 997 turbo and it’s tucked up in the garage, up on the scissor lift. I’m reading plenty of stories about seizures of turbo components though, and I’m wondering if it might be better to take it out every 4 weeks or so on a dry day, to keep everything working. What do you think? What do you do?
Realistically, how much salt is going to be on a dry road several days or weeks after it snows? Especially in the UK where it rains and washes the streets frequently. Packing these cars away to be untouched for months only makes sense to me if you're somewhere that has constant snow and salt out.
You could also just spray the actuator rods with lithium grease or WD40 and they shouldn't seize.
Thanks guys. Interesting one - spraying the actuator rods. Anyone got experience of this? Does it work? What about turbo shafts seizing - anyone had that over winter?
Still wondering what to do. There's a scissor lift hiding under my car, so I can easily raise it if needed.
I still try to drive mine periodically when it's warm enough for me to wash it when I get home, including a good undercarriage hose down.
I change the oil / fill the gas tank / add fuel stabilizer / plug in battery tender and let it sit for winter, moving it occasionally without starting to preserve tires - no starts over winter months.
Thanks Johnny, yes I had seen that. Starting to think a dehumidified garage and monthly actuator rod wiggle might be the way to go! 4-5 months of salt and grit/stones here in UK
