Bent sway bar. Is is trash or can it be salvaged?
This is a RSS 3 hole adjustable front sway bar for 997 tt. Not sure if I should try repair, sell or throw it away?
Best i can guess is all was repaired but the sway bar stayed and he then put Moton club sports bc B16s were on a long back order.
This is my best guess why it's bent.
Replace.
While you can bend steel, no matter how you do it, there will be a change in the structure. While this may be OK for some components, in no way would I trust a suspension component that had been bent and re-bent back. Definitely replace it.
It's junk. Last thing you want is a swaybar with even a minor asymmetrical tweak.
