Wash wheels - then rusty rotors?
I do pre treat with P21S so not sure if that makes a difference, but inevitably this rust will get slung all over the wheels or sort of leak out if they get wet at all when driving making a clean wheel dirty. Is this normal with cross drilled rotors?
What am I doing wrong?
This is normal for any rotor that gets wet and the water sits on there. Even after a hard rain you can see this on rotors. Once you drive and hit the brakes a couple times it will gone.....nothing to worry about
Similar to above, I blow my rotors dry at the end of a wash and don't have any rust dust afterwards. I use a MasterBlaster - it's awesome! Between that and spotless rinse, I barely have to touch the car to dry it.
