View Poll Results: 2.7 or 4.0
2.7
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
15
19.48%
4.0
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
62
80.52%
Voters: 77. You may not vote on this poll
If you could own only one; 2.7 RS or GT3 RS 4.0
This man's reaction after driving the 2.7 put a big smile on my face. Almost as wide as the one he's wearing!!
I think it just shows how some cars just bring out the inner child.
I had a similar experience with a Lamborghini Espada 1972. Not the best car by far (though maybe my favorite Lamborghini), but what a ride!
The 2.4 was just another level. Beyond anything I have seen or experienced.. so I can't even begin to imagine what a 2.7 is like.
Cheers!
I guess that depends on your definition of driving ? If ultimate speed is your metric, then yes, the 4.0 RS fulfills that role admirably. If however you're seeking to experience the engagement, tactility and those very unique 911 handling "traits", on the road, at sane speeds, you'll not find them in a 4.0RS (nor indeed would I suggest any 997).
So as no one has attempted to describe the experience of driving any of the cars suggested to the OP, let me be the first throw my hat into the ring with the 964 RS.
For the sake of context, this was written in response to a comment on a UK forum about an 964 RS selling at a European auction for £220,000 ($287,000) back in 2014 whereby another forum contributor stated the RS couldn't be worth 55 times more than a £44,000 ($57,000) Boxster.
55 times better than a Boxster ? That depends on the criteria you're judging them by. They're 55 times more rare, of that I'm certain. And that, I suspect, counts for a lot.
I'd say they're 55 times more engaging, tactile and "special" to drive than any Boxster too.
0-60 ? Quite frankly if that's your benchmark for what makes a car great (or not great) you most likely won't get the RS.
Overly stiff ride ? Grow a f*cking pair (it's an urban myth, so get one with decent, modern tyres (ie not ten year old Michelin MXX's) fresh dampers, sensible geo settings and ride heights, and you'll find them an absolute blast for A & B road hooning.
Build a rep on the cheap ? yep, course it can be done, but it's the little things that make these cars more than the sum of their parts. Take the ali bonnet for example, lift it up ('cause there's no gas struts to assist you) prop it up using the aluminium strut (who's end goes into a specially formed nut that doubles up as the securing nut for the strut top mount).
Pull on the inner door latch release pulls (formed from doubled up loops of seat belt material) feel the way they release the door latches so mechanically (then try the pastiche of the same idea on the Cayman R and feel how, as a sop to the RS, they've tried to incorporate the same idea into a door trim that wasn't designed for it (neither was the release mechanism) and feel how utterly sh*t it feels in it's action when compared to the original. It's what happens when the marketing men decree what goes into a car, rather than letting an engineer decide.
Put the dainty key into the ignition switch and turn it against the perfectly weighted spring loading of the switch. Just as your wrist starts to run out of articulation, the starter kicks in and the flat six bursts into life. If your foot isn't on the clutch, you'll hear the sound of the gears in the transmission rattling away as the lack of a dual mass flywheel (and the harmonic damping it usually provides) allows the gears to chatter excitedly within their casing.
Sit there and wait for some heat to percolate through the flat six, and soon after you'll be able to hear the thick, glutinous oil coursing through the pipes running the length of the car as the precious life blood is pumped towards the thermostat, only to be sent back to be warmed further without troubling the car's oil cooler.
Press down the floor hinged clutch pedal with it's initially awkward over-centre action, then gently palm the slightly baulky gearlever into first. Press the accelerator expecting the tardy, nee lazy, damped response most modern cars provide, and find this car's powerplant reacts instantaneously and you've just encouraged the rev counter around to 3000rpm, and not the 1200rpm you'd intended.
Try again, but being too timid, you stall it .......
Another attempt, this time you succeed as the car's low down torque aids your franky pathetic attempts to master the over-centre clutch, the hair trigger throttle response and the recalcitrant gearbox.
Out on the open road, the oil temperature gauge shows signs of life, the gearbox becomes less baulky and the steeringstarts to lighten with speed.
Twenty minutes in and the engine is now nicely warmed through. Let the fun commence ......
From your gentle fifth gear cruise, change down into third and slowly depress the long travel, floor hinged throttle pedal all the way to it's stop. The induction noise hardens and increases in volume, the drivetrain grumbles as you accelerate through the rev range and the lack of dual mass flywheel creates harsh resonances that sound more akin to a coffee grinder. But keep accelerating and they'll disappear to leave just the mechanical sound of the flat six along with it's induction noise and the cooling fan shifting vast quantities of soothing, cool air over the barrels and cylinder heads buried within the bowels of that nondescript looking engine compartment.
At 6,800 rpm in third the game's all over and its time to start the process all over again in fourth.
A quick, gentle lift of the throttle, along with a short, quick prod of the clutch, allows you to thread the perfectly weighted, short(ish) throw, gear lever through the gate.
A corner approaches, so you lift off the throttle and change down, you get back on the throttle and turn the steeringwheel, initially the helm feels stodgy, heavy and unresponsive, you curse the lack of power steering (LHD cars only) as the nose seems unwilling to cooperate with your request for a change in direction.
But wait, the wheel in front of you isn't the sole method of altering the car's trajectory, next time try using the brakes to keep the weight over the front wheels whilst you turn them, then carefully chose the moment to get back on the throttle (hard) to utilise both the grunt of that flat six AND the traction afforded as a result of its position over the rear wheels.
Suddenly 260hp seems more than enough to make indecently rapid progress, but more than that, you're a simply massive part of the process of going fast, you have to be, because without your guiding hand, your perfect timing, your ability to deftly come off the brakes and seamlessly reapply the throttle, this car doesn't steer, it needs, no relies, on you to manage it's imperfect weight distribution.
It's hot sweaty work in the summer, no aircon along with no insulation means that a large part of the heat generated by that 3.6 litre engine finds it's way into the cabin. Soon your back will be wringing wet and that "moist" feeling is only exacerbated by the leather facings on some of the most perfectly formed bucket seats ever to grace a car. Supportive enough to enable you to retain control without having to hang onto the steeringwheel, but not so all enveloping as modern race seats.
On the right roads, driving experiences don't come much better, or indeed more intense.
And when you've had your "hit" of the RS, you won't feel the need to race home too, instead you'll be happy to potter at 6/10's, watching as other far more powerful cars overtake you, safe in the knowledge that despite what the manufacturers of their cars may tell them, their owners will have little or no idea what tactility, engagement and fun behind the wheel really are.
Finally you'll arrive home, hot, sweaty and possibly slightly deaf..... You'll undo your seatbelt, remove the keys from the ignition, wind your window up and step out.When you slam the door shut, two things will stand out :
Firstly the delightful noise the door makes when it closes. Partly a function of it's bank vault build quality, and partly the fact that it's unencumbered by door pockets, airbags, central locking motors, electric windows or their switchgear.
And the second thing that will stand out when you slam the door shut ? A light, gentle, barely discernible tinkling noise...... wink
Those that have owned and driven these wonderful cars will most likely know what this "tinkling" noise is, whilst those that think they're an overpriced, underperforming, anachronism, probably won't. But neither will they care........
GT3 player par excellence
^ i dont have long hood RS. but driven several. i have a 4.0
you are RIGHT ON.
the long hood, you either "get it" or you dont....
it's not over priced. i just dont have enough money...
you are RIGHT ON.
