DME Report Advice.
Can you give me your opinion on this DME report. It's been a long time since I have read them in the past but forgot what is what. Thanks
Whats is the total operating hours?
Do you have a tune?
Definitely there iare alot of over revs but the other question is when was the over rev in relation to the total operating hours. Per my mechanic the last time I inquired, atleast 200 hrs from the last one to feel comfi in an over rev.
Do you have a tune?
This car looks to have been driven pretty darn hard. Unless the over-revs were quite a while ago, all wear items taken care of, and really cheap, I would pass. There are a lot of 997 turbos out there and you can find better examples with less abuse.
Just my limited opinion.
The one in range 5 from what I understand is less than 1 second. And happened 80 hours before the others and I know the car is driving for a while without any issue. I'll try to find out the current hours.
Do you have a tune?
Do you have a tune?
"I was just wondering if when I go to resell if buyers are going to panic and run."
It would difficult to get the most $ out of it or even take a long time. Put 200 hrs out of it before you sell it then do a compression test, then maybe, you can remove the stigma of this DME.
