Center Lock Nut
Center Lock Nut
OK, my question posed here is how to dissemble the center lock nut to check for proper lubrication. The usual diagram shows an exploded view but does not outline how to separate the cone to access the other parts. Does the grease just hold it all together or have I missed something?
GT3 player par excellence
chk text
There is a wire ring that snaps into a groove that holds everything in place. Don't try to pull it apart. The grease will eventually push it apart, then deal with it. It's easy to take care of.
