GT3 vs TurboS susp geometry differences?
Hi, weight aside, what are the inherent suspension advantages of the GT3 versus the 997.2 Turbo S? Also not including adjustable sways/thickness of sways, and the fact GT3 comes with ride adjustable coilovers.
I'm more talking about things like the links, arms, geometry etc. Things that can't just be overcome with putting on some coilovers on the TurboS. I'm curious to know. I've seen some pictures where the GT3 coilover/upright is angled more (more caster?) versus the Turbo S. I'm not sure how all that works and how that all affects handling.
Here is a good read for you albeit this is for 997.1, it still applies. The turbo/s has standard carerra bits.
http://www.elephantracing.com/tool-b...n-overview.htm
Diff between stock 997.2 GT3 and stock 997.2 Turbo/S:
Front lower control arms- different
Front thrust arms- same
Front subframe- same
Front uprights- different
Front struts- different
Rear lower control arms- same (different for RS and 4.0 version)
Rear thrust arms- same
Rear upper arms(aka dog bones)- same
Rear uprights- same (different for 4.0 version)
Rear subframes different
Rear toe links- same (different for 4.0 version)
Rear shocks- different
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
Tom,
The subframes have solid bushings as well compared to rubber for the rest.
Yep. That's the only difference, rubber vs metal bushings. A very popular mod that we do for non-GT cars is replace rubber rear subframe bushings with metal to eliminate slight movement of the rear suspension independent from the chassis. The metal bushings are thinner by around 10mm so the rear suspension pick up points are raised which is good for lower ride heights. Burning out the rubber bushings with a touch is messy work but a worthy mod for track cars.
GT3-variant front struts and rear shocks have shorter stroke(less travel). The front uprights have raised axle centerline and matching height for outter tie rod connection. And GT3(and C2) front uprights puts the struts at a more straight position, whereas Turbo/C4 front uprights puts the front strut at more angle in order to accommodate front driveshafts.
