Anyone changed their gauge faces on 997.1 GT3??
Hi,
Wondering if anyone has attempted this?
Let me know as I would like to do the same...
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
I have done it a couple of times in fact, because I messed up the first time I did this and was to brutal with one needle and broke the small servo housing trying to fix it. It's actually not to difficult as long as you are very careful and follow the instructions to the point. The hard, or most important part, is removing the needles. They have to be pulled straight up without much side movement. Protecting the gauge face and using small forks or something similar to push up from under the centre of the needle solves that issue quite nicely. Using two plastic forks where the teeth has been broken off (or something similar) from opposite sides of each needle gives stable upwards and no sideways pressure when popping the needles up.
Here is the DIY instruction: http://www.planet-9.com/planet-9-art...faceplate.html
I am strongly considering replacing the stock gray/black gauge faces on my GT3 with yellow ones to complement the exterior color of my car.
My plan is to buy a used gauge set off of eBay so that my original gauges remain unharmed.
Like these:
http://r.ebay.com/i9jsdy
Buy the yellow faces from FVD.
https://www.fvd.net/de-en/F976412210...anual-mph.html
What, if anything, will I need reprogram to make the new gauges work?
Anyone have any thoughts on where to send the gauges and face plates for the replacement? I have seen the instructions and it is not impossible, but rather nerve wracking and I would rather not mess it up.
Finally, it is a bummer that the FVD gauge plates do not have the GT3 logo. Does anyone make a good quality set with the logo?
Thanks!
--Tom
Like these:
Thanks!
--Tom
Like these:
Thanks!
--Tom
Like these:
Thanks!
--Tom
