Side muffler delete with Sharwerks?
I currently have the SW bypass and am searching for something more as well.
One of the options I'm considering is the SW track exhaust + Evoms software.
Quote from SW:
With the exhaust and software, the gains were higher, bringing it up to 414 RWHP at the peak (22 RWHP net gain), more torque at the peak, and a large gain in torque between 3700 and 5400 RPMs.
Anyone have any experience with this combo?
Quote from SW:
There is also a good simple option with very little parts needed.
- Side muffler both deleted.
+ add this to cancel the drone around 3000rpm if you commute on motorways etc too ----> https://rennlist.com/forums/997-gt2-...ess-drone.html
+ if its still too loud - just adjust the length of the centre muffler inlet runners a little inside the muffler (I can't recall if we added or removed some length of pipe (25mm), but boy it makes a huge volume difference). Not hard for any good speed shop familiar with Porsches.
Sounds like a cup car when I am on the gas....and I talk on the phone on the way home from the track and actually can hear......all the best.
Quote from SW:
Quote from SW:
Base on the dyno from my gen1RS, the center and side delete dose not show any peak HP gain. I had both side and center bypass together, and it is the lightest setup you can have (360WHP). Had tried Cobb stage2 tune and peak power is about the same. Just a bit more power at mid range. Disappointed from the claim!
If you are after the significant HP gain (30whp) get a set of catless header from Jamie, period.
Be done and get Dundon/RK setup.
