Why my brake pedal goes soft on the track
How worn is the differential? With the stock diff plates that wear out on track quickly, the inside rear wheel wants to spin exiting the slower corners. The TC even when turned off will use the rear brake to grab the inside rear rotor to slow the wheel spin and over heat the brakes. A lot of gt3's rear calipers are much darker than the front because of this overheating. Rebuilding the diff will help a lot. The rear gt2/gt3 cooling ducts are helpful as well. I have seen this quite a bit at one of our local tracks with a lot of braking zones and slow turns. Might not be the issue but worth a look. Jack up on side of the car and spin the rear wheel to see how much break away torque the diff has.
Does your shop have different set of calipers around?
In these situations you have to start eliminating variables
In these situations you have to start eliminating variables.
Former Vendor
To me it sounds like your calipers need to be rebuild properly using the correct parts and technology.
We rebuild calipers here so we could do that for you.
I have an OS Giken LSD that's two years old and works fine as far as I can tell. My rear calipers are the same color as the front and show no signs of overheating, although I have seen this discoloration on other cars. In fact I've checked caliper temperatures with temperature strips, temperature sensitive paint, and an IR pyrometer. The temperatures never go much over 300F.
Unfortunately no.
Unfortunately no.
Bleeding is always done mechanically with somebody in the car working the brake pedal.
Could this just be a massive knockback issue from worn out wheel bearings? The tap of the brake before the turn that you suggested would validate this condition.
It's definitely not wheel bearings, although I did investigate this possibility earlier. Front wheel bearings were replaced a while back, although not the rear. The thing is that the "long" brake pedal persists even when the car is standing still, as long as the brakes are hot. As I said before, you can see a visible gap open up between the pistons and the pads when you let off the brake, and the tap closes it up momentarily.
Trucker
1) for me back to the basics: are you sure that your system is bled properly? There are always theories about bleed process, but some believe in modulating the ABS valves while pulling vacuum to get all air / all fluid out.
2) Wilwood makes inline residual pressure valves. You can get them in 2/5/10 psi. I have used them in race cars but cars built from scratch and not factory cars such as yours. The primary purpose has to do with brake fluid drainback.
I wonder if this could be some sort of venting issue causing a vacuum. Maybe get an extra reservoir cap and drill a tiny hole in it and see what happens.
Your Porsche Parts Superstore
![](http://www.paragon-products.com/v/vspfiles/assets/images/pagidrs2.jpg)
![](http://www.paragon-products.com/v/vspfiles/assets/images/Paragon web logo.gif)
![](http://www.paragon-products.com/v/vspfiles/assets/images/konilogobkbgsm.jpg)
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
Former Vendor
Originally Posted by mm450exc
Problem found! Very much uneven pad wear. Pad 10mm at top and 5mm at bottom! So was basically running on 50% of the pad - heat!
When the pads wear down past 60%, more heat gets transferred to the calipers as well. The compound also serves as some insulation for the caliper as well. Very much a hydraulic issue as well as the fluid and piston seals get taxed.
A lower wearing pad which generates less heat would be good to consider next time around.
