How to tell if slotted rotors are too worn (photo)
When you can't see the slots anymore....
^ Yeah, I'll only be concerned if your slots are starting to "blur" into the rest of the rotor.
The manufacture should spell out min thickness but to be honest depending on driver/operating conditions etc you should make an educated guess when to retire them - failure isn't funny.
Basic Sponsor
Unless a crack develops going to the outside you will be good until the slots disappear. The small hairline separations you see on the rotor face are not cracks but heat stress fractures. These babies look like they have tons of life left.
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
This can be tricky to measure if the pad is not completely covering the full swept area of the rotor. You can get irregularities because the pad is not interfacing on the outer edge of the rotor, which can culminate as not being able to properly measure the true thickness of the wear surface. For whatever reason I didn't have trouble with this until I got a new batch of PFC pads from my new supplier. The pads cover about 95% of the actual surface for some reason - I guess these must be cup pads, not GT3 pads.
http://www.amazon.com/Anytime-Tools-Caliper-Electronic-Micrometer/dp/B006Y1OWKS
