997.1RS transmission mounts?
I now have my coolant pipes fixed, LSD rebuilt and transmission refreshed.
Time to put it all back together.
Looking to see what you folks think of transmission mount options? Stock? aftermarket? Pros? cons?
75A polyurethane mounts in mine. NVH def much worse--almost halfway to a cup car when it comes to flywheel chatter at idle / transmission noise at low speed. Handling is a big improvement: mid-corner shifts engage very positively.
A good tradeoff for track use in my case.
I should have mentioned that the car is going back to showroom stock with only casual track days from here on in.
Given the noise of the harder tranny mount I will stick with stock.
Mooty doesn't mod his cars other than e88. That picture of that hippie cayman? It's all stickers. The wing is actually a sticker. So is the window net. It's really a showroom stock cayman r. :-)
I agree the hard durometer mounts are loud. Especially with the cup cables. The cantrell softer mounts are much firmer than stock with only a bit more NMH. At thunder hill there is the 11-12-13 sequence that I drove before and after transmission mounts, without I had a hell of a time on the 2-3 upshift. With the mounts the 2-3 hit much easier. So yeah, for me it made a little difference.
I might be last man standing with a 997.1RS not taking it back stock.
I concur with comments above...
Tq solutions 95a gear box nose mount
RSS engine mounts
Cup cables
Numeric shifter.
Minus - Noisier plus more increased vibs.
Plus- better body control in transition from drive train movement containment and much improved 2nd to 3rd shifts at high rpm and lateral loads
Still worth it for spirited road use.
Plus don't listen to mooty he is only interested in dealing with standard cars so has a vested interest in you completing the OEM refit.
RSS engine mounts
Cup cables
Numeric shifter.
