How to remove rear side trim panels?
I bought a set of yellow seat belts for my car.
Need to remove the rear side trim panels to install them, and I'd like not to learn anything the "hard way". Did a quick forum search, but did not find anything.
If anyone can give me some tips, or direct me to a good source, I'd appreciate it.
thx
thx
- Remove A-piller trim, they snap in with metal clips in the pillars of the body (pull outward I believe). It will expose a phillips screw on the B-pillar trim panel that the top of the seat belt is attached to. Remove that.
- Unbolt the top of the seatbelt anchor/slider on the B-pillar, and remove that larger bolt that holds it. The bolt is under a plastic cover on the seat belt loop if I remember.
- The B-pillar trim panel that the seat belt is attached to is now ready to come out, it pulls outward/up at the same time. Pretty easy.
- Now the seatbelt will be flopped over the quarter trim panel you are attempting to remove. There is a T25 torx bit where the B-piller trim panel meets the large side panel, remove that.
- The entire side panel can come out now, it is snapped in the same as the A-piller trim panel. Grab it by the door sill side and give it a decent pull, but only pull about 5-6" off when the clips unsnap as you have to remove the speaker wire on the side panels otherwise it will break the plastic clip. Continue to unclip all of the way toward the rear of the car, the clips won't break so don't worry if they make odd snapping sounds.
- Revere to re-install.
You don't have to remove the panel fully but just the front edge - I have a cage so did it this way to stop a load of pain and time removing the cage first and then the rear quarter trim just to fit belts!
PS partly remove the door seal along the edge wear the trim meets the door- you will finger it out. Its not a hard job- 30 mins each side tops- 15 if your quick.
What will you be doing w/ your Black belts? I have Yellows now and they are a bit too 'hey, check out my seat belts!!!' for me.
sry, double post... (shame)
1) They're original to the car, and there's the voice in the back of my head that says that might matter a lot to the next owner (in the unlikelihood that I might ever sell it)...
2) Some day I might feel the same way you do now
I'm thinking of doing the same (have black belts in black leather/cf interior and its muted) so if you could take some pics of the 'more difficult' steps when you do the 2nd side that would be appreciated! Thanks
And how does the big cap that covers the seat belt D-Ring slider come off?
I started doing this, but maybe I'm not following the instructions right? I can pull the A-Pillar trim outward from the metal, but the A-Pillar piece is actually trapped UNDER the B-Pillar (see picture). It's also trapped by the instrument panel. So it seems the B-Pillar actually needs to be out to get the back of the A-Pillar out?
You don't need to do all this. Changing the front belts and removing the tear panel is really simple. I removed my black belts and switched to yellow and had it all done in 30 minutes.
Take a look at this:
http://www.6speedonline.com/forums/9...ual-guide.html
In spite of having the battery disconnected throughout the entire disassembly/reassembly, I now have the airbag light on (sounds like same happened to the poster of the above instructions). Is there a DIY way to reset this, or does it need to be done by a dealer?
