.1 Durametric Coding Error Codes
I borrowed a Durametric 6 pro from a generous RL'er and coded out my thorax airbags since I removed my stock seats and replaced them with Recaro fixed back buckets. I also coded out my TPMS at the same time using the really informative thread below.
https://rennlist.com/forums/diy-subm...etric-pro.html
Airbags: My airbag error light is no longer there but it still blinks about 8-10 times on start up and the stays off. I've read from some others that it blinks 3 times.
I changed the following airbag items:
Driver and passenger thorax airbags off
Driver and passenger seatbelt chimes off
AWS off
I have two error codes. When I scan for codes in each module using the durametric.
1 in the airbag module C152 "Communication PSM Control unit (drive)".
1 in the gateway module C136 "Communication AWS control unit "comfort".
Any ideas if these two errors mean anything or need to be addressed?
AWS off
i've never pulled these codes to see on mine... I DO know my airbag light flashes about same as yours however.
Still blinks more?
