Thinking about stepping up to a GT3
I don't daily drive the car. I take it to work maybe twice a month. It's for weekend fun, road trips with the wifey and DE events. I'm running about 5-6 weekend events per year but would always like to do more :-)
Currently I swap in a 996 GT3 seat and Pagids for track events and usually leave them in.
I knew about the coolant fittings and LSD issues.
I realize the car is stiffer and less "streetabable" but I'm concerned with wearing out my C2S.
I guess another option is finding a nice 997.2 GTS and doing some mods to it.
Thanks for the help guys.
AEsco48, might be awhile. Just doing preliminary research to narrow the search. GLWS though.
don't bother with a gts if you want a gt3. gts is a hopped up 997, the gt3 is a totally different beast.
gt3 is 100% track ready with only necessary (vs. FUN) mods: pinned coolant lines, upgraded diff, rear toe links, brake fluid, pads, good tires, alignment/balance, safety equipment. That's all you NEED.
GTS you'll spend a lot of $ trying to get it to feel and drive like a gt3, and that will be expensive.
I'm in the same boat, except I'm not into track use. I currently have a 997.2 C4S, but I take public transportation to/from work every day, so my desire is for occasional weekend toy. I don't care for Turbos and I hate, er, despise, the 991. I would love to get into a .2GT3 as upgrade for Sunday drive on a sunny day only. Would you guys not recommend? Sounds like, from reading your posts here, that if no track use, GT3 is a waste of $$$. Am I interpreting correctly?
and i think as NAM VET was saying, the DD potential really depends on what you're used to. sure the clutch and suspension are stiff, but i haven't had any issue punting around town in it. in fact, if anything it's made me want to make the clutch in my RS4 stiffer since i feel like i'm going to put my foot through the floor when i go from the GT3 to the RS4!
What do the toe links do? I've run my car about 4-5 days and it was tracked before I bought it and my diff still appears to be working fine. No floaty feeling under hard braking and it's getting good traction to both wheels on low speed tight corner exits. Maybe it's been replaced before?
Yes, this.
it is not a problem whatsoever.
never seen the track, because if I did, I might as well start doing heroin too.
To take the other side, the non-GT3 cars can be exceptionally fun on the track. I tracked my 996 C2 for 7 years before making the jump. Unless you think you're better than the car, I wouldn't put yourself in financial distress to get a 3. Coilovers, sways, roll bar, and seats are a lot cheaper than the upgrade. Solid motor mounts and new mufflers can give you half of the raw feel for cheap.
That said, the GT3 is awesome and worth the money.
Well, this is an option as well. I'm not faster than the car. It's more of a longevity situation. I'm in a 997.1 C2S which has the underlying IMS issue. It's also a street car and as such is under more stress than it was designed for. The Metzger is a pretty tough engine comparatively.
I'm not jumping into anything as of yet but just gathering info. I like the idea of a 996.2 GT3. Although I like the looks inside and out of the 997 cars better, theres something about the rawness of the 996 cars that seems more challenging.
Just traded in my '06 C2S for an '07 GT3. If you're not going to track the car, keep your 911. If you do trade, consider additional $'s for coolant pipes, after market slip differential, etc. Cost me 11k over and above price of car.
