Iron Rotor Advice, please....
#31
Basic Sponsor
Hi. Regarding the rear with a floating hat, does the handbrake still work if fitted to a street car?
350x28mm Rear: Retail $1398 per pair, iron replacement rings $339 each
This is why I ask. It's got a custom engineered hat i think. http://www.prtechnology.com.au/produ...andbrake-drum/
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services
Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs
Ferodo Racing Brake Pads
Spiegler Stainless Steel Brake Lines
704-824-6030
jeff.ritter@essexparts.com
Jeff Ritter
704-824-6030
#34
I currently have the PFC slotted 378mm front rotors and CENTRIC drilled rotors in the back, running PFC08 pads front & rear and have been following this discussion rather closely as the options certainly have increased vs. a couple of years ago.
Right now I need new rear pads (CENTRICS hold up amazingly well, much better than OEM Turbo rotors!), and new front rotors rings.
Did a bit of research and put this (non-exhaustive) table together as a reference for the different price points.
- PFC is the most expensive, on hats, rotors and pads.
- AP Racing is close second
- GiroDiscs (either from APEX or Craig) are almost $300 cheaper than PFC.
Cost of replacement rotor rings varies by around ~$100, so for me to switch from PFC to either AP or Giro based on price point alone does not make sense.
Quality-wise, my first set of PFC rings cracked within 12-15 events. The 2nd set is holding up very well after at least 30 events. No suspicious cracks, but grooves / slots are almost gone...
#35
^^^ PPCB from the looks of things?
Great reference material. I was wondering what it would cost to go steal. Now I know! Thanks
#40
Basic Sponsor
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
#41
Sorry for the ignorance, but with all these different options on the rotors can you still use any pad?
My front pads and rotors have only a few months left in terms of life and looking for a nice alternative. I'm planning to track about 5-6 times a year.
#42
Basic Sponsor
Our Essex/AP Racing discs are now shipping. You can definitely get something cheaper, but you cannot get something better. Call Clark at Apex to get some now.
#43
Basic Sponsor
I'm not sure about the other brands, but with our Essex/AP Racing J Hooks you can use any pad that would work with the OEM discs. Our discs are dimensionally identical to OEM.
#44
Do the rear $100 centrics have the exact same cross drill pattern as factory? Just curious if visually they look the same.
Wish they made a front set. That is silly cheap even if they only last several days.
#45
I thought I read the fronts do exist but I can't find the info now. I doubt they would only last a few days, guessing they would last about as long as stock rotors based on my experience with those rotors on other cars.
