GT3 over rev question
Hi all!
Considering on buying a 2011 GT3. Car has 22k miles and all checks out. But there is a problem!
Over rev count came back
Range 1 148 539 operating hours
Range 2 131 539 operating hours
Range 3 57 539 operating hours
Range 4 24 539 operating hours
Range 5 none
Range 6 none
Price is good, like the car. Should I be Concerned?
Range 5 none
Range 6 none
If a test ride then drive keeps the CEL dark the engine is running just fine. No compression test or leak down can tell you any more.
And the test ride/drive also lets you check out the rest of the car along with the engine.
If you like the car and you can use this to your advantage during negotiations then get it. Especially if you plan to track the car. The engines can take the abuse, but at some point they need attention. That means opening them up to see what is going on. The good news is unlike the newer P-car engines there are many techs that know how to work on them.
If you like it, buy it. You will not be sorry.
GT3 player par excellence
car is fine
with at total hour he miles is low, leak down will not show anything
u can do it, a correct leak down color is $1000--500
u will have great numbers
So I found another GT3 with only 3 ignitions in chamber 3. Waiting for tomorrow for the PPI to come back.
