While the engine's out for coolant pipe fix...
#31
Good question, I'm not an expert. Haven't heard of folks with non-RS engines having trouble - but a lot have converted to the single mass and 4.0 clutches, so you never know.
#32
This seemed to affect the 3.8 rs and possibly 4.0 engines. have not heard on 3.6 engines due to single varicam design. Not sure anyone has determined a real cause although harmonics is often cited it could be just a bad bolt design or torque spec
#33
Odd that my dealer would not re-torque, they insisted on installing new ones, which took over a month to source from Germany. Maybe they rev'd the part.
#35
I did not bother with the water pump - unless yours has a problem.
The gas filter OTOH is a pain to replace and I did do that. Check all lines and make sure there is no wear... Also front and rear main seals.
I also did the LWFW and a bunch of other more costly stuff
Ray
Ray
#36
My list. I wanted some cool hop up parts to go with the not inexpensive service. This one hurt a bit:
Coolant pipes welded, replaced all gaskets, o-rings, all rubber hoses, clamps, new rs4.0 clutch, pressure plate, flywheel, bearing, clutch fork, shaft bearing, front/rear main seals, water pump, expansion tank, thermostat, bbi under drive pulley, new drive belt, 996 cup short shifter, 996 cup shift cables, Guard club-sport diff, oil change, tranny fluid change, Cantrell transmission mounts
#37
