question about rear toe links (locking plates)
Yes, just the elephant plates should work. The stock toe links run out of eccentric range (too short to achieve toe in) if you try to get over 3 degrees of camber through control arm shims and adjustment. That's when adjustable links are a must, or elephant makes an eccentric bushing for the stock toe arm which I am using now.
![](https://c6.staticflickr.com/8/7245/27079747725_c492b71bfb.jpg)
The front is adjusted through shims and not an eccentric bolt right? Is the bushing for the front or rear stock toe arm? Looks like a rear in the pic.
