Coolant loss + coolant smell front radiator vent
Hmmm... since you don't see any coolant anywhere... There is a good chance that is it. Fill it up. Distilled water. Watch it.
Do you know if your shop used a vacuum tool to get the coolant back in there?
Read that thread that was posted a few weeks ago about the guy who busted a pipe in Canada on a long drive. Describes keeping the bleeder valve open, doing drive cycles, to get the air out, and topping up. I forget exact procedure.
haven't read through whole thread, but rad issues are common, replaced all mine with CSF...
to get air out of system without vacuum tool(not needed at all)...engine fully up to temp., radiators 'flowing', bleeder valve 'up', rear of car elevated(jack, up a hill, etc.) and rev the engine to say 4k RPM for short-periods...will self-bleed quickly, bleeder valve/tank need to be the high point of the cooling system for air to escape, don't want any air pockets, RPM helps move coolant/air-pockets out
s yeah,but it works. Autozone will loan you one...Just don't buy anything there except stuff in the drink cooler.I used to start em cold,hold a paper towel over the exhaust.Look for traces on the towel.Look for white smoke,coolant smell.Make sure it's coolant,not condensation.
I think so, leaky radiator may be sucking in air during when cooling/cold('sealed' system that has displaced coolant)....air could be stuck in numerous places in the cooling system
Sounds like stuck thermostat in the video.Is the car running hot?Run it with cap off,see if it's flowing when it reaches temp.Air lock shouldn't cause coolant loss.
Bought car with 16.4k miles - drove it 200 miles home, no issues that I could see, but didn't check coolant level before and after etc
Sharkwerks did coolant pipes and pin'ing on it at ~17.25k miles
Drove a few hundred miles, did one autocross last weekend, noticed that at hot coolant was at min level.
Drove 150 miles yesterday, noticed it was now below min. Now at 17.8k miles.
Only ever used the heat once, that was just right when I bought it to make sure it worked, haven't honestly tried since.
Last night pulled front bumper and rad shrouds, ran car up to 200 degrees rev'ed engine a handful of times to run pump harder, then looked closely at radiators, and lines, no leaks. Rev'ed and smelt exhaust, no water no smell of coolant no smoke.
Gurgling on shutdown and reducing coolant level only signs of any issue, no water on floor of garage
Car didn't run hot at AX, but I haven't really run the car all that hard period (no track days yet). Never seen the water temp move higher than between the 200 and 225
Total history:
COOL!!!! I had a Pantera and my brother had a Mangusta back in the day.Goodyear made tires to suit it..351 was serious.My favorite car I ever owned was a Ferrari 512 BBTI Boxer.I think DeTomaso had something to do with it.I just sold my gt3 to buy a Ford gt to do a round the country tour while we still got one
