I had a drive recently in a bone stock 6.2 GT3 and the steering is so much sharper, more direct than my 7.1 GT3. I understand the the 7.1 has variable ratio and that probably explains the difference. So am wondering if it's possible to retrofit one in my car.
"Like other 997 911s, the GT3's steering ratio is variable, which is intended to increase high-speed stability. Thankfully, it remains constant until you really crank the wheel, at which point it speeds up — but this only comes into play in low-speed maneuvers; if you're cranking the wheel far enough to invoke the faster ratio at high speeds, you have worse problems than the variable steering ratio!" ~ Car and Driver
On my 97.1 RS, don't see how it can be made so ....
on other models, pump is monitered through track control, but here I don't see what could make that ....
maybe 97.2 ??
