997 GT2/GT3 Forum 2005-2012
997.2 GT3 has 2x downforce over 997.1?
Old 08-06-2014, 12:03 AM
  #31
ShakeNBake
ShakeNBake's Avatar
GT2RS Front 14Kg, Rear 35Kg
GT2.1 Front 9Kg, Rear 29Kg
Old 08-06-2014, 02:11 AM
  #32
John Chan
John Chan's Avatar
It is hard to compare without knowing the set ride height and rake angle of the car.
A stupid shop set my front way high like a rally car and the car was undriveable at speed. No traction in the front and dose not respond to steering input at speed.
Old 08-06-2014, 06:25 AM
  #33
woshimihei
woshimihei's Avatar
Go big or Go home
Old 08-06-2014, 10:40 PM
  #34
Serge944
Serge944's Avatar
Originally Posted by Mvez
Considering what little the .1 had, doubling it would be pretty easy. Anybody who has driven both, will tell you there's a considerable handling and aero leap from the .1 to the .2. Not BS.
Exactly. Either car produces very little downforce. The stability you're really feeling is the lack of lift, which most other cars produce.
frederickcook87 (09-12-2022)
Old 08-07-2014, 02:43 AM
  #35
Fisher
Fisher's Avatar
OK, I'll buy the no BS bit, IF you can explain a significant difference, "more than twice as great" between the downforce of the .1 GT3 and .2 GT3, excluding the difference created by the larger angle of the .2 GT3 rear airfoil.
In other words, I believe the angle of the rear airfoil on my .1 GT3 could be increased to create a downforce very close to that of a .2 GT3.
Anybody buy that?
Old 08-07-2014, 06:06 AM
  #36
Ur20v
Ur20v's Avatar
yes but the cost of drag, I believe the later aero produces the goods at less cost.
Old 08-07-2014, 08:59 AM
  #37
Riz
Riz's Avatar
Any info on downforce for 996.2 GT3. The front feels light on that car at higher speeds. I would like to improve that.
Old 08-07-2014, 09:03 AM
  #38
997gt3north
997gt3north's Avatar
Anybody buy that?
Yes - It is more accurate however to say that the .1RS can easily get and exceed the downforce levels for the .2GT3 and my guess is close to .2RS levels with the addition of the cup front lip. The .1gt3 airfoil doesn't quite have the size and shape to give the same numbers as the .2GT3
And no I do not believe there will be much if any different in drag. (see drg numbers below comparing the cars). The .1 cars (gt3 & RS) were set up to have substantially lower Drag than the .2 cars.
You can search and find an interesting wind tunnel article on the .1 gt3 car. Simple by raising the rear of the car approximately 10mm (thus increasing the car's rake) and effectively running the rear spoiler at its highest level (they used a slightly more curvy rear spoiler replacement) you increase the rear downforce greatly and you also get slight front downforce because of the rake. They then retested the same car with effectively a front cup lip and by doing so you get front downforce numbers similar to cupcar's (which somewhat surprising is quite low - last gen cars)
When you look at the numbers comparing the .2 cars below, the .2 RS comes with a higher 'standard' rear wing 'OE' rake than the gt3 in the OE position and the 4.0 comes with and even higher OE rear wing rake level again and further adds a higher rear ride height versus the 3.8RS to add to the rear DF #s (look at the .35Cd vs .33Cd drag numbers of the 4.0 vs the 3.8 RS).
If you take a .1 RS car, run the rear wing at 13-15 degrees (close to the 4.0 wing rake level), run the front cup lip spoiler and 4.0 or other canards, the cars will be 'close enough' aero-wise - the difference will be down to HP/Tq and the 3.8's better gearing.
GT3RS4.0 Front 14Kg, Rear: 58Kg on lowest setting, 0.35Cd
GT3RS.2 Front: 11Kg, Rear: 49Kg on lowest setting, 0.33Cd
GT3.2 Front: 15Kg, Rear: 19Kg on lowest setting, 0.32Cd
GT3RS.1 Front: -2Kg, Rear 10Kg, 0.3Cd
GT3.1 Front ~0, Rear ~0, 0.29Cd
Old 08-07-2014, 09:08 AM
  #39
AudiOn19s
AudiOn19s's Avatar
lower the front to add chassis rake and add cup splitter. Will be much better.
Additionally you can tilt the radiator, open up the top of the bumper for the center radiator to vent out the top and seal the lower bumper openings to force that air out the top of the car and it reduces lift even more. (Al La cup and RS)
Old 08-07-2014, 05:40 PM
  #40
Fisher
Fisher's Avatar
Loads of thanks for the reply! Just what I wanted to know.
Old 10-10-2014, 08:18 PM
  #41
AEsco48
AEsco48's Avatar
Originally Posted by 993GT
Based on other 996GT2 aero specs(5lbs FRONT/18lbs REAR d.f. at 125mph,... 120lbs combined d.f. at 190mph) , that listed spec for '6GT3RS doesn't seem right...I've seen 0lbs(neutral) front lift/d.f. for 6GT3 at 125mph
993GT... You are famous!
Watch the video!
http://jalopnik.com/i-spent-a-day-dr...awe-1643930570
Old 10-11-2014, 03:03 AM
  #42
993GT
993GT's Avatar
at least he hasn't read about pinning vs welding....
Watch the video!
Old 10-11-2014, 12:01 PM
  #43
tcsracing1
tcsracing1's Avatar
the difference from the .1 and the .2 is so drastic that the .2 gets worse fuel mileage and has slower top speed due to all the drag... lol
Quick Reply: 997.2 GT3 has 2x downforce over 997.1?
