Need Track Tires for 997.2 GT3
#46
I currently run OEM size RS3s from the closeout. They are a steal and will get me around the track in a hurry. I can hold 1.1G with them without a problem. I don't care that they are 2010 production. They work fine and last. Flip them and they last longer. I'll also run them backwards in the dry if I have been one direction for too many days.
#47
I think it is good advise to start off with a street track tire. I ordered a set of the RS3's and got the close out deal. I am going to run these until I become more familiar with tracking the car then I will probably upgrade to something like the R6. I appreciate all the information, it was extremely helpful.
#48
GT3 player par excellence
#49
if u have dynamic engine mount, try NOT to jack up on engine case
#51
I admit not reading this thread,but I did see something about jacking up the car by the engine??!! I really hope I misunderstood this part....NEVER NEVER NEVER jack up the car by the engine!!!!
Use the crossmember or something strong part of the chassis,NOT the engine!!!
#52
997.1 not dynamic engine mount
Asked this question earlier and consensus was to jack up on the case
Other option is aluminum cross member connecting rear suspension - people like that better?
#53
You need to understand the stresses you are putting on mounts,lines,transmission etc...not to mention to the case,oil pan etc.
The only time you put a jack underneath an engine is to support it if you're changing the mounts,dropping the tranny,or if you need to gain a few mm clearance by jacking up or lower down after disconnecting the mounts.
I hope I made myself clear...
#54
Have giant torque wrench, floor jack, jack stands on order. I do have dynamic engine mounts. From reading another thread, it looks like there are jack points under the car. I would appreciate it if you could clarify.
#55
jack on rear jack point (right in front of rear tire)
out one stand under front jack point
put another jack under rear sub frame support.
repeat the other side
#56
however I prefer jacking rear jk pt and put support under sub frame, this way u jack 2x. if u jacked split case, u need to jack 3x to get car on jack.
#57
Mooty,we can agree to disagree...
This is where you jack up rear so you can put jackstands on left and right jacking points : notice the big ol' silver crossmember behind that black stabilizer bar-right in the middle you put your jack. Not engine. It's not fine.
#58
Ultimately it's all not a big deal unless you are constantly jacking up the car then yes you don't want to be using the engine I agree
#60
They will be my next set.
