GT3 Picture Thread
#1666
All 4 legs of the bar should be attached. The front 2 mount where the end of the seat belt would attach if you have sofa seats. The rear 2 are the same way and mount where you'd have the belt on a model with rear seats.
The following 2 users liked this post by WP0ZZZ:
EMpunker (04-27-2021),
RallyeChris (04-28-2021)
#1668
#1669
Cobalt
Here's a couple glamour shots of my GT3 with the photographer's like colored Turbo. He was also kind enough to capture me out on the track.....
The following 11 users liked this post by karmx7:
Elliotw44 (04-27-2021),
Joe Cho (04-27-2021),
jonwb (04-28-2021),
Manhattan_trout (05-29-2021),
and 6 others liked this post.
#1670
#1672
Seats out of the car
Bar fully removed from the car
Prep all the holes for bolts
Use New bolts only
Coat all the bolts with anti seize
Make sure you have all 4 bolts started before you tighten any one down.
Have a ratchet or two on hand to squeeze the bar if necessary. Sometimes the holes won't line up perfectly. You may have to massage the bar a little, with the ratchets, to get the holes to line up properly.
Start wrenching down the bolts.
Just an FYI, your car is safer with no bar than the way you currently have the bar mounted. Fix soon.
Good Luck, it's a nice bar btw.
#1673
The threaded holes exist in the chassis but on models with no rear seats like the GT3 they are capped off with a plastic plug which itself is covered with some seam sealer type of stuff. You will have to pull the carpet to locate them.
#1674
There are holes back there . You have to poke through the carpet.
Use New bolts only
Use New bolts only
The following 5 users liked this post by silviaks:
daddyscar (05-04-2021),
EMpunker (05-05-2021),
MGT3 (05-04-2021),
Robocop305 (05-04-2021),
rrichmondd (05-04-2021)
The following 5 users liked this post by ABT_SLC:
Elliotw44 (05-05-2021),
EvilllEmpirE (05-05-2021),
Joe Cho (05-05-2021),
MGT3 (05-05-2021)
The following 4 users liked this post by bretster:
#1678
The Blue loving enthusiasts spoke at the Carlisle Swap Meet - People's Choice....
I do it,... because it's the best parking spot on the day for $10!!
.... 1st place was a guy from Carlisle who told us he brought all his family & friends (highly modified 2008 turbo, white). now THATs the way to win a people's choice!
The following 8 users liked this post by bweSteve:
Burren (05-11-2021),
jonwb (05-13-2021),
jreifler (05-28-2021),
limitedslip (05-13-2021),
milazzo_997tt (05-11-2021),
and 3 others liked this post.
#1679
Mustard and Ketchup.....
The following 4 users liked this post by EvilllEmpirE:
EMpunker (05-18-2021),
keep it lit (05-22-2021),
The following 4 users liked this post by tq.3z:
