NT-01 temperature question
About to put on nittos for the first time on 2010 gt3. Going on to track for first session what would be ideal pressure setting (running 18" wheels) and coming off track what pressure level should i regulate the tires to? Any other advice about these tires is more than welcomed
I just worked in a new set of 245/305s on 18" and started around 26 then regulated to 33/35hot. Seemed pretty good for first time out.
Let us know what you think of them-
Peter
on my Carrera GTS but with stuffer (GT3 like) Bilstein Damptronics....NT01 at 32/33 hot work great. Anything above 34 hot seems to lose grip. I start out at 26 all around and adjust from there.
Otherwise known as tire pressures are like girls. Some like them hot and high pressure and some like the cooler low pressure models.
My pressures are set by hot tire temps from Pyrometer readings as well as my camber.
Peter
Peter
