While the engine is out... .1 RS
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
What should I replace? 997.1 RS with about 14k miles. Some track miles from former owner but no over-revs not even in the lowest zone so I'm thinking a very careful driver. RMS being fixed under CPO by local dealer.
I'm thinking coolant pipes pinned or welded IF the dealer will agree to do it. If not should I have them re-glue them?
What about the Sharkwerks pipes? Worth it or is my car too low mileage?
Water pump
Clutch/PP probably too early.
Anything else? Thanks!
Water pump
If all they are doing is RMS they should only need to drop tranny, not engine. Did you confirm they are dropping engine? If only tranny and you plan to track, guard diff rebuild for sure while tranny out.
I am going to be getting my pipes welded in early summer during track break. This is what i've asked shop to inspect and/or fix in addition:
--I bought those little shark pipes, will have those installed. Shop confirmed these do leak, and break, they do not break catastrophically like the coolant housing pipes
--Replace all rubber hoses and hard to get at rubber stuff.
--New guard diff
--Inspect / replace RMS and inspect/replace FMS (as needed)
--Replace water pump
--replace clutch (I have 34k miles on mine) and inspect pressure plate, replace if needed
--New guard diff
--New guard diff
--New guard diff
The Rebel
--New guard diff
--New guard diff
Out of pocket this is a big bill, mostly labor, but will get some increased perf along with (diff, clutch maybe) plus minimize fear of blowing a pipe while on track (already running WW). But we're stewards of these cars right? :-)
And while GT3DE 4.0 comment is a little tongue in cheek... yes that is an expensive bill. But if you want the POWER!!!
Get them pinned like so:
http://sharkwerks.com/porsche/techni...urbo-cars.html
I'd be surprised if the water pump needs replacing that early... Other than that maybe get your 4.0 LWF/PP stuff done. If you need an LSD... that's the time also?
Honestly I wasn't planning on any performance mods at this point, budget constraints with a new kid and new business being what they are and for the next few years very few track days. I'm looking for reliability and a way to prevent what I can in case I was unfortunate enough to get a coolant hose blow off while at the track. WW is not optimal given the car is still under warranty.
Reliability-wise:
- coolant lines welded/pinned/reglued
- sharkwerks pipes
- water pump since I'm there
- rubber hoses.
Performance-wise:
- 4.0 clutch / pressure plate
- Guard LSD
- 4.0 conversion (I WISH!!!! Maybe I could kickstarter it)
Anything else?
Reliability-wise:
- sharkwerks pipes
- rubber hoses.
Performance-wise:
- Guard LSD
Anything else?
