LF: CL Breaker Bar & Torque Wrench
I got the Snap-on torque wrench that reads from 100-600 ft lbs. They actually make two, one is digital and it breaks down into a smaller package BUT you cannot reverse its direction and use it as a breaker bar. The one I got is the standard "click" style that is internal spring preloaded. It is 42" long but you can set a higher torque, reverse the direction and use it as a breaker bar. One tool that will both loosen and re-re torque the nuts.. not cheap though.... but then neither is the Porsche
Tooltopia sells the Precision Instrument split beam and is reasonably priced too. A number of forum memembers have used it.
http://www.tooltopia.com/precision-i...s-c4d600f.aspx
Snap On sells direct on their website too
Rob
Precision tools 3/4 torque wrench around $300
Breaker bar from same place about $70 or so (don't remember exactly)
Use a cheater---(part of a handle from a floor jack)--to slip on the end of the breaker to get more leverage.
When breaking the wheels always push down---don't pull up---your back will thank you.
Air guns are a No No as the bolts are alloy unlike the Cup car set up.... Just use a breaker bar... The Porsche collapsible one doesn't fare well with the revised 600Nm torque setting. Don't waste your time with this option...
GT3 player par excellence
